I've done a lot of reading and searching, but i'm trying to find a good turbo upgrade that doesn't require any supporting mods that most of the turbos mentioned use to get the most out of them.
One of my stock turbos has given up. So i need to upgrade, but don't want excessive lag. Any ideas? GT2860R? I'm just not sure what version.
cheers,
andrew
https://www.sau.com.au/forums/topic/160654-stock-gtr-turbo-upgrade-help/
Well what constitutes "worth the effort"?
Stock turbos will run into the low 300rwhp quite happily.
There is not a huge amount of room between that & the point where your AFM's & fuel system run out of puff.
As for cam gears. There is a thread somewhere where bear baron has posted a dyno sheet of the before/after results. Most useful. The cam gears that is.
I'm wondering the same thing.
What would you say the minimum supporting mods would be for say a GT2860R to make it worth the effort?
Do you need computers / cam gears etc etc.
yes.
Generally Fuel pump
ECU, Cam gear, full exhaust, decent clutch... they are all a must.
Injectors if you want a little bit more out of it as your likley to max out the stockers before you max the turbos.
Cheers
I went the 2860R-5s, Great mod. As above really... ECU, Low restriction exhaust-inc, dumps and front pipe, free flowing cat and cam gears. Then the next spend would be turbos, fuel pump and the injectors ...unless you want to plonk down the coin all in one go. Then 32R suspension GB then some reliable gauges then wheels then ...... :ermm:
If you don't want/have any support mods then the smallest of the three version is the one for you.
:laugh:
But mis_quoted I believe.
GT2850R turbo's come in 4 Versions.
N1,SS,-5(2530),-10(GT-RS).
Buy either the N1, or SS.....same size housing as the stock unit no EPA probs.
Cheers
