I've done a lot of reading and searching, but i'm trying to find a good turbo upgrade that doesn't require any supporting mods that most of the turbos mentioned use to get the most out of them.
One of my stock turbos has given up. So i need to upgrade, but don't want excessive lag. Any ideas? GT2860R? I'm just not sure what version.
cheers,
andrew
https://www.sau.com.au/forums/topic/160654-stock-gtr-turbo-upgrade-help/
Well what constitutes "worth the effort"?
Stock turbos will run into the low 300rwhp quite happily.
There is not a huge amount of room between that & the point where your AFM's & fuel system run out of puff.
As for cam gears. There is a thread somewhere where bear baron has posted a dyno sheet of the before/after results. Most useful. The cam gears that is.
I'm wondering the same thing.
What would you say the minimum supporting mods would be for say a GT2860R to make it worth the effort?
Do you need computers / cam gears etc etc.
yes.
Generally Fuel pump
ECU, Cam gear, full exhaust, decent clutch... they are all a must.
Injectors if you want a little bit more out of it as your likley to max out the stockers before you max the turbos.
Cheers
I went the 2860R-5s, Great mod. As above really... ECU, Low restriction exhaust-inc, dumps and front pipe, free flowing cat and cam gears. Then the next spend would be turbos, fuel pump and the injectors ...unless you want to plonk down the coin all in one go. Then 32R suspension GB then some reliable gauges then wheels then ...... :ermm:
If you don't want/have any support mods then the smallest of the three version is the one for you.
:laugh:
But mis_quoted I believe.
GT2850R turbo's come in 4 Versions.
N1,SS,-5(2530),-10(GT-RS).
Buy either the N1, or SS.....same size housing as the stock unit no EPA probs.
Cheers
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
