For sale are my BSA/ANZ Tycoon Hyper wheels. They are in perfect condition with only the front left rim having the slightest gutter rash (can hardly see it).
Currently has 60% Maxxis tyres on the rear and 40% Pirelli P-zero Nero's on the front (bloody expensive and still grip like shit on carpet)
18 inch x 8 inches wide
5 x 114.3
almost certain that its a +40 offset...maybe +38? (currently on an r32 with no guard scrapage lock to lock - sticks out a tiny bit so it looks good)
Tyres are 235/40/18
$1000 $900 $850 $750 firm
Contact me on:
M: 0402 502 537
E: [email protected]
or PM
Pick up Melbourne eastern suburbs or buyer pays freight costs interstate.
Edited by dan.1337
Hey man,
Would you consider a swap plus cash adjustment.
Cheers
i'd prefer to not swap as i'll be returning the wheels back to stock and would prefer cash.
$900 negotiable with 4 good tyres guys!
hey man, i'm in kew. they'll be off my car before the end of the week and u can trial fit them then.
if it makes it any easier, we can meet in the middle somewhere.
Bump!
I have to have these GONE.
Open to reasonable offers =)
Let me remind u that the tyres are all very good, esp the front Pirelli Nero's which are about $500 a pop by themselves. There is also only one small bit of gutter rash if u can spot it in the big wheel picture above.
Feel free to ask any questions or want a trial fitting.
How can I find out whether these will suit my R33 GTST? I don't know much about offsets...
R33 are supposed to be +20 according to this site http://meggala.com/wheelsoffsets.htm
hey dude,
i think u were looking at the r33 GTR offsets with a 10 inch wide rim and 275mm wide tyre with offset +20.
according to the site, these offsets with tyres will fit:
SKYLINE TYPE M R33
18X8.0 +33 225/40 R18
18X9.0 +39 255/35 R18
from what i know, the offset is the distance between the inside edge of the wheel hub and a space with measurement +xx. using that, the site u sent me and the tyre dimensions on mine as 235/40 R18 offset +40, i can almost be sure that it'll fit well as the +39 255/35 R18 is almost the same offset (-1 diff) fits and my tyres are 20mm narrower which means that it shouldn't rub on your guards and it won't stick out too much (10mm smaller on either side).
correct me if i'm wrong, but i'm almost certain that's the way it works and therefore it should fit perfectly =)
feel free to ask anything more.
Edited by dan.1337
hey dude,
SKYLINE TYPE M R33
Thanks for the info!
I've been warned by a friend about buying 2nd hand rim's this big... that warping can be a problem. That all it takes is a pothole or something and you can leak air and have to refill your tyres every week. So I guess my question is... have these rims ever met a gutter or a (large) pothole? Do they maintain air pressure?
no probs.
there's no leaks in the tyres and i haven't had to top them up since i got the car as they've held pressure. they haven't hit any large potholes or gutters either. i'm always cautious not to drive over them as it screws with the sussy setup too.
they also haven't been tracked or dragged so there is no chance of them being warped through that either.
I reckon they look good on your car. Don't know why you would sell them!
hahah thanks, but i'm selling them as i'm a bit strapped for cash atm and will be going back to stockies for a lil while.
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
