C/F and fibreglass is very brittle, be very careful when drilling as the bits can grab and make a rough edges. I'd recommend using a small rotary tool with a fine grinding bit. Just mark out the size of the hole and grind carefully. Should get a better result than a drill.
I don't like drilling carbon/fibre, because as people have said, it's brittle. But, bonnet pins for those bonnets are pretty much mandatory. I don't know how many times i've seen it where those carbon bonnets have flipped up due to flexing etc.
That's why I still run the stock bonnet.
yeah I'm not sure what man whore is reffering to, but I've never had any trouble. you want a good bit, in good condition with fine pitch. and a high drill speed. put masking tape over the area you want to drill. drill a very small pilot hole then away you go. I've uised this technique to drill from about 1mm thick to about 3 or 4mm thick. you can finish the hole a bit with a light, fine, round file.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
