The price is pretty good if you don't need to worry about organsing to buy it, you can get it cheaper elsewhere depends on how quickly you want it. $240 seems okish for an install hope that also includes them configuring it as well ???
---Updated---
Nengun = AU $ 503.36 + shipping = $546.30
Greenline = AU 503.735 + Shipping = ???
But keep in mind that these ones you may also have to pay import tax etc so i would actually buy it from him unless you want to get one second hand.
Also depends on if you are going to buy another ecu later. If you are then an AVCR is probably overkill. It does some of the simple things that an AM ecu does.
If you can get a boost controller for sub $400, then you are wasting $200? but if you don't intend getting an ecu for a while then the AVCR is a good cheaper compromise.
I was told the PowerFC boost controller plug in was not soo good.
I'd love for someone to actually show me some funky stuff with the AVCR when i do my high-flo upgrade.
The standard ECU will remain in place, I doubt it will ever be replaced. But it is being retuned by CEF11E once the turbo is finished being high flowed. I’m also getting a bigger fuel pump put in. so I think I should be pretty happy with the final product. Edd at Integra tells me the turbo should have no problems doing 220+ rwkw. But as far as I know I will probably need bigger injectors. As I think the standard RB20 items will only flow enough for around 200rwkw
I wasn't saying not to buy a boost controller. The pfc one is OK, but basic, you would better with a dedicated evc no arguments from me there. What I was saying is that an AVCR is a boost controller plus a boost response controller. This is also done and done much better by a pfc.
If you aren't getting a pfc then its no problem = spend an extra $200 and get the AVCR.
If your plans include a pfc then get a $400 boost controller and put the $200 you save towards your pfc.
PS See this: http://www.skylinesaustralia.com/forums/in...howtopic=162435
  tridentt150v said:
re: spiking?
My understanding from the manual, is that once you start to spike you need to work on Solenoid duty timing and the like.
Of course this requires more work and testing, but i plan to let people far more knowledgable than i tune the bejesus out of it at the time.
I-Colour - very nice. Haven't read all this thread but I just had one fitted and I think it's the "ants pants". Yeah it has heaps of functionality and 4 boost settings which may well be deemed overkill. However, I like it 12, 15, 18 and 22 psi. It's going to be nice to go to the track and just select channel 3 (18psi) 300 awkws, boast or boost :)
It's extremely precise and very easy to use, configure/set. Gets my vote also for the amount of info that is displayed.
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
    • Evening all. Got this odd issue with my R34 GTT. If I let the car idle for around 15 seconds or more (even when cold) and I jab the throttle a bit, a decently sized plume of blue/grey smoke comes out the exhaust. Doesn't smoke when idling alone, just when giving it some gas after idling. No smoke on cold start or from what I know, normal driving. Not 100% sure about smoke on decel but I don't think there's any. Any pointers on what I should start doing to troubleshoot it? Or if anyone has experienced the same I'd love to get some insight. Cheers.
