The price is pretty good if you don't need to worry about organsing to buy it, you can get it cheaper elsewhere depends on how quickly you want it. $240 seems okish for an install hope that also includes them configuring it as well ???
---Updated---
Nengun = AU $ 503.36 + shipping = $546.30
Greenline = AU 503.735 + Shipping = ???
But keep in mind that these ones you may also have to pay import tax etc so i would actually buy it from him unless you want to get one second hand.
Also depends on if you are going to buy another ecu later. If you are then an AVCR is probably overkill. It does some of the simple things that an AM ecu does.
If you can get a boost controller for sub $400, then you are wasting $200? but if you don't intend getting an ecu for a while then the AVCR is a good cheaper compromise.
I was told the PowerFC boost controller plug in was not soo good.
I'd love for someone to actually show me some funky stuff with the AVCR when i do my high-flo upgrade.
The standard ECU will remain in place, I doubt it will ever be replaced. But it is being retuned by CEF11E once the turbo is finished being high flowed. I’m also getting a bigger fuel pump put in. so I think I should be pretty happy with the final product. Edd at Integra tells me the turbo should have no problems doing 220+ rwkw. But as far as I know I will probably need bigger injectors. As I think the standard RB20 items will only flow enough for around 200rwkw
I wasn't saying not to buy a boost controller. The pfc one is OK, but basic, you would better with a dedicated evc no arguments from me there. What I was saying is that an AVCR is a boost controller plus a boost response controller. This is also done and done much better by a pfc.
If you aren't getting a pfc then its no problem = spend an extra $200 and get the AVCR.
If your plans include a pfc then get a $400 boost controller and put the $200 you save towards your pfc.
PS See this: http://www.skylinesaustralia.com/forums/in...howtopic=162435
re: spiking?
My understanding from the manual, is that once you start to spike you need to work on Solenoid duty timing and the like.
Of course this requires more work and testing, but i plan to let people far more knowledgable than i tune the bejesus out of it at the time.
I-Colour - very nice. Haven't read all this thread but I just had one fitted and I think it's the "ants pants". Yeah it has heaps of functionality and 4 boost settings which may well be deemed overkill. However, I like it 12, 15, 18 and 22 psi. It's going to be nice to go to the track and just select channel 3 (18psi) 300 awkws, boast or boost :)
It's extremely precise and very easy to use, configure/set. Gets my vote also for the amount of info that is displayed.
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
