Hey all
well ive installed GTR injectors and these resistors
click
which have the same function as a gtr resistor pack.....
got a retuned ecu, for the injectors and plugged the z32 afm in which it is all tuned for...
the pump primes, the fuel rail has fuel in it.. but she just wont spring into life..
i have checked and rechecked everything!, installed it twice because i checked all the wiring... those resistors have the same function as the gtr resistor pack...
reset the ecu.. EVERYTHING...
anyone at all got any ideas on why she wont start? been working on it for 2 days now and ill have to remove the gtr injectors and put stockies back in if it keeps on like this!
Thanks
Ed
Edited by Haysey
https://www.sau.com.au/forums/topic/160663-desperate-for-any-help-at-all/
Fuel + spark + cranking = start.....hence the usual questions;
Does it have spark?
Is there unburnt fuel on the spark plugs after cranking?
Is the ignition timing correct (timing light)?
>_< cheers >_<
Does it have spark?
>_< cheers >_<
changed the sparkies the other day and drove it no problem
didnt touch anything except change the injectors and add resistors....
didnt touch ignition timing from when i drove it last.....
its gotta be a problem with the injectors!
i put them on the 12v wire, the one that has one common and splits for each injector as seen in roys diy....
i need someone else here, isnt the best way to put a screwdriver to the injector and listen through that?
i really think they arent firing for some reason
I'm with SK on this one. If he doesn't know the answer, then there isn't an answer.
Stupid Q - are the fuel lines on the right way around?
i was stressing that they werent because i didnt know the fuel ran from the back of the rail to the front... but ive checked engine bay pics on my computer to how i have it today and they are fine.....
im going to wait for another set of hands and check spark and make sure the injectors are spitting..... but i cant do that alone
ok pretty sure the injectors arent going
reason being is i disconnected the fuel rail and tried to test them by myself and they kept blowing off the fuel rail so hence alot of fuel got down the injector hole......
i went to crank it and it sprung to life briefly
now if ive wired the resistors correctly and installed the injectors right why arent the injectors firing?
Product Detail
PF Part Number: 344515
Manufacturer: WELWYN
Manufacturer Part Number: WH5 68R JI.
Description:
RESISTOR, 10W 5% 68R
* Resistor element type:Wirewound Aluminium Clad
* Resistance:68R
* Power rating:10W
* Tolerance, +:5%
* Tolerance, -:5%
* Temperature, operating max:275°C
* Temperature, operating min:-55°C
* Temperature coefficient, +:50ppm/°C
* Temperature coefficient, -:50ppm/°C
* Temperature, full power rating:20°C
* Case style:Axial
* Voltage rating, AC:160V
* Centres, fixing LxW:12.5x11.3
* Depth, external:9mm
* Length / Height, external:17mm
* Resistance, insulation:10000mR
* Temperature rise:22.2°C
* Width, external:8.9mm
CEF11E did the exact same thing on his rb20 and it worked, he was the one that told me to get the resistors
I know it sounds simple, but;
Have you chucked the stock ecu back in and tried it?
With a z32 and bigger injectors on stock ecu it will still fire, possibly even run (badly). You should probably confirm that your afm wiring is correct aswell.
You've changed, injectors, ecu and afm. You haven't checked anything but injectors from what i've read.
Oh, and if it's a daughter board, check that it hasn't slipped out of the socket. Seen it happen on s13's.
ive tried all the combos, at the moment the rb20 afm and my old (not stock) ecu is back in there..
as it should run the gtr injectors but will just run dangerously lean in the top rev range...
the cradle is firmly soldered in there and the chip is simple to change no problems there...
wired up the afm according to a diy, but left the old plug on there so i could change it if i needed to.....
maybe there is too much resistance and the injectors arent getting enough power?
still waiting for a mate to come over and crank it while i miltimeter it
Ed, do you have an alarm that could be interfering with the injector pulse from the ECU ?
sounds silly, but an option to look into, as when i coverted my shit box lancer to manual i changed over to the manual ECU - but didnt work, spent forever tesing it to find the injectors not spraying - turned out the the chip runs from the ECU and this is the fuel cut - swapped to auto ECU and worked
Product Detail
Description:
* Resistance:68R
* Power rating:10W
* Tolerance, +:5%
* Tolerance, -:5%
* Case style:Axial
Resistence is meassured in Ohms, I don't see any Ohms on that spec list. They should be around 10 Ohms, best to check measure them with a multimeter.
:blink: Cheers :)
when tested with a miltimeter they read between 67-69
ive prob had it at a too high setting and there should be a decimal point in between there
a little off 10ohms, but not that far....
ive been told they are " 6 wire wound 10 watt 6.8ohm resistors"
chris, i think my alarm cuts the engine in other ways, although something to check for...
smokey should be here in 20 to help me when i pull the injectors out and see if they are firing and also test the resistance......
The GTR resistor pack measures up from memory low 5 ohms, the 280ZX and MR30 resistor packs measure up in the high 5's; up to 10ohm resistors won't cause a problem as they have been used in the past without issues.
Rip the CAS out and leave it connected, turn the ignition to the on position and spin the cas while listening for the injectors.
Spin it obviously in the same direction the motor would turn.
As others have said.. Ensure the fuel lines are the correct way around. Double check your Z32 wiring and last of all double check your ecu.
yeah i used a spare fuel rail and injectors i had to check they were firing.
is any fuel coming out of the fuel pressure Reg when your trying to start it? also if the fuel spits at you when you take the hose off the FPR then the lines are around the worng way :wave:
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
