FOR SALE!!
RB25 Turbo, came off my skyline due to upgrade to bigger turbo. Was only ever running at 7psi boost, has no shaft play. Was pulled off by professional performance workshop, and he said that the turbo was in excellent condition. Perfect as a replacement for a blown turbo or for someone wanting an upgrade for their RB20.
Will post a pic shortly, but very simply, theres nothing really exciting to see.... its just a standard turbo, very clean, comes with everything including waste gate actuator.
Looking for around $400, this turbo is one fo the few floating around still that actually genuinely is in good condition.
contact via PM or ph. 0423 033 529
Cheers,
Jason
P,s, located in sydney area... willing to meet for pickup, also willing to post anywhere!
  • 4 weeks later...
BUMP!! surely some one needs or wants a really good condition R33 Turbo either for a replacement for a blown one or as a spare... My new turbo cost me alot of money so i need to sell this one asap. Cheers guys!
  • 4 weeks later...
Does nobody need R33 Turbos anymore? Surely theres plenty of guys out there who have blown theres when they up their boost a bit too high by mistake.... Anyway this turbo is unboosted, running stock 7psi. and is in ubelievably good condition.. you will be very surprised as to how good this turbo is for a second hand. No shaft play and has been checked by professional performance workshop when they took it off to install my new bigger turbo.
  • 4 months later...
sorry to whore this thread but i also have a stock rb25 turbo for sale
looking for similar price, no shaft play, good cond. will post photos in separate thread soon
pm for more info, pics in my gallery
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
