DAAM!!
they werent leanient with that screw driver either...looks pretty deep...I'd be pissed. no alarm im assuming....
and its situations like this u cant really do alot unless u catch em red handed...so if u do...let me know :wave:
feel for ya
DAAM!!
feel for ya
theres an alarm, it just isnt sensitive enough to react to that i guess.. If i caught them red handed though, id lay the smack down.
this kinda crap happened to a guy in a turbo lancer near my house, i came along about 5 mins after and the guy was practically driving, about half and hour later i see them driving around with about the other car loads of people with bats and poles looking for the guys that did it,
my point is, people that scratch cars are losers :wave:
fark me dead... hate to see this kinda crap happening... what's worse is theres really nothing that can be done to stop idiots from keying people's cars...
i still remember parking my car outside one night... some sh!theads decided it was a good idea to squirt some PVA glue down the side of my white skyline. luckily, i came out just in time to wipe most [yes, some was left and dried and cant be removed without removing some paint] of it off cos it was still wet... ohh mate if i knew who did it...
:ermm::yes:
deriq
I know just how you feel man.
I owned my R33 for 3 days when someone keyed mine. Right outside the front door of my work too. What really sux is that they didn't just key one panel. They went right down the passenger side from the front quater, through the door and onto the rear quater. All right throught to the metal.
Could have killed someone :ermm:
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
    • Front seats now in, fixing a little rust then front doors sealed up again finished. had to install a fire extinguisher within arms distance of drivers seat for hill climb regulations. little bit of good old silo diff action lol IMG_9146.mov
