hi, does anyone know what type of lights to use in the xenon system for the r34. The lights lense has a sticker on it saying it has been converted to xenon and not to attemt to use any other gas type. so the lights that are advertised with xenon gas are they safe? or will i damage the system ?
and that real annoying beep how in gods earth do you by pass it to shut up?
( plss plss its driving me nuts)
you sure it says converted to xenon not halogen. As for the beep, yeah it pisses me off too
wait yours beeps in reverse. ha ha weird i thought you where talking about when the key is in. Is that standard ?
Edited by nsm034
its got a xenon logo on the lense. so im sure its xenon.
my 34 is auto and when you select the reverse gear it beeps to tell you it in rverse??? so annoying
Just because it says xenon does not mean you have xenon. The lamps would have been replaced to halogen during compliance so I don't think you have xenons. Are ur lights a bright white color and takes a few secs to come on? If so you have xenons...if they are the normal yellowish light, then its been converted to halogens.
if they're converted to halogen it will probably have numbers engraved into the top of the light sort of where the bonnet sits. I'd say your xenons have been chopped out like mine. If so you just get normal h1 halogen bulbs ( i think its h1 , haven't changed them for a while) from autobarn etc. I've heard phillips have good bulbs. The high beam is something diffent but i don't know what it is. Sorry i got a manaul trans so cant help with the beep
that sounds about right its been etched out with a H1 12v/55w serialed into it. The high beam is a tricky one i know never heard of it before.
does anyone out there know how to by pass it and have no sound while reversing ?
You are correct alot of em loose xenons when complianced but mine was left in and alot of others i have talked to theres were also left.
i got the reverse beep aswell.. i think its normal..
yeah its bloody normal.
There is a wire u can cut... apparently if u pull off the plastic covering around your gear selector there will be a wire attached somewhere near the "R" setting u simply cut it.
where is the beep coming from ? Under the dash ? Stick your head where it's beeping and see if it has a beeper/ speaker somewhere and pull the wire going to it
As above... but in saying that I have not cut mine nor look in there as it does bug me when reversing for a while but don't want to damage the interior surround.
so in compliance do they just change the globes or did they change the whole set up? i have xenon, but its been converted back to halogen, want needs to be dont to get it back to the factory xenon? bloody compliance, why cant they just leave stuff alone...
cheers
cheers
Can't simply change back in most cases they cut the wires out making it impossible to fix. Need new headlights basically. Also they usually take the ballasts.
It's a piece of piss to take the surround out mate, look at http://www.r34gtt.net/r34start.html
Hey,
I had a look at that site but couldn't find the bit about the interior console, i've seen that site b4 but didn't realize he modded the inside or had info on it.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
