Hello all
Got a mate looking to get some Volk Rims for his car (s2000) and after a long and painful (paid - waited - no rims - no refund - court etc) he still has no luck. Now hes talking Bob Jane jobbies and we just cant have that.
Any ideas on dealers that could help. Especially a WA dealer. Any help would be great as his stocko 16" rims just do do the car any justice.
Thanks.
https://www.sau.com.au/forums/topic/160723-volks-in-wa/
http://tech9tyres.com.au/
heard these guys can get some speciatlty rims or maybe try http://www.c-red.com.au think they also can get some of the rarer stuff. Both in WA, or try one of the traders here on SAU. JDMIMPORTS or JDMConcept i think.
cheers
Evil
https://www.sau.com.au/forums/topic/160723-volks-in-wa/#findComment-2985784
As above, getting them in from JDM, Slidewise Imports EBAY auctions etc... is probably gunna be cheaper and contain a wider range than Perth suppliers
http://www.skylinesaustralia.com/forums/in...howtopic=143549
But I understand if he's had trouble in the past.
https://www.sau.com.au/forums/topic/160723-volks-in-wa/#findComment-2986005
aye dude my mate has a set of volks in f**king mint condition from his s2000 let me know hes selling em for a good price
they the correct offset and width as specified by rays for the s2000 and they are in 18s
cheers
andrew
https://www.sau.com.au/forums/topic/160723-volks-in-wa/#findComment-2991264
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
