Hello all
Got a mate looking to get some Volk Rims for his car (s2000) and after a long and painful (paid - waited - no rims - no refund - court etc) he still has no luck. Now hes talking Bob Jane jobbies and we just cant have that.
Any ideas on dealers that could help. Especially a WA dealer. Any help would be great as his stocko 16" rims just do do the car any justice.
Thanks.
https://www.sau.com.au/forums/topic/160723-volks-in-wa/
http://tech9tyres.com.au/
heard these guys can get some speciatlty rims or maybe try http://www.c-red.com.au think they also can get some of the rarer stuff. Both in WA, or try one of the traders here on SAU. JDMIMPORTS or JDMConcept i think.
cheers
Evil
https://www.sau.com.au/forums/topic/160723-volks-in-wa/#findComment-2985784
As above, getting them in from JDM, Slidewise Imports EBAY auctions etc... is probably gunna be cheaper and contain a wider range than Perth suppliers
http://www.skylinesaustralia.com/forums/in...howtopic=143549
But I understand if he's had trouble in the past.
https://www.sau.com.au/forums/topic/160723-volks-in-wa/#findComment-2986005
aye dude my mate has a set of volks in f**king mint condition from his s2000 let me know hes selling em for a good price
they the correct offset and width as specified by rays for the s2000 and they are in 18s
cheers
andrew
https://www.sau.com.au/forums/topic/160723-volks-in-wa/#findComment-2991264
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
