roger roger, will do some research :stupid:
People claim some impressive numbers with simple SAF-C tunes on 1J's... I have a mate who was keen on a 1J into his laurel but was put off by cost estimation. Would be keen to know approx cost of the loom.
What are your guys estimates on a completed 1J conversion not incl exhaust and front mount?
https://www.sau.com.au/forums/topic/160742-jz-ceffy/page/2/#findComment-2994975
depends on how much of a cheap ass D.I.Y-er u are :stupid:
changing the engines is pretty straight forward, as stated above custom engine mounts have been produced in s.a for a very cheap price( same as normal mounts) den buy ur self a 1jz engine loom and use the front engine plugs by just cutting them off with sum wire left 2 soldier onto the rb loom wire,
the loom plug mite be tricky.... if theres da same number of wires to the loom from the 1jz and the rb it shud be easy
https://www.sau.com.au/forums/topic/160742-jz-ceffy/page/2/#findComment-2995007
depends on how much of a cheap ass D.I.Y-er u are :dry:
We're all cheap ass DIY'ers aren't we? :) Looms are scary though..
d0rid0ri if you have time post some pics :)
https://www.sau.com.au/forums/topic/160742-jz-ceffy/page/2/#findComment-2995231
do the custom mounts bolt up to the RB20 cross member? full aftermarket computer would easially be the way to go about it, instead of splicing, cutting and correcting with OEM looms.
i might do some sums and see what comes up :(
best price i could do for a 1jz manual half cut was 3k from a jzx81
https://www.sau.com.au/forums/topic/160742-jz-ceffy/page/2/#findComment-2995874
btw my 2JZ in aristo made 255rwkw with an SAFC tune, exhaust and FMIC and thats through and autobox :(
would be easy another 20rwkw with a manual
A31: 3K for a manny hc from a JZX81 is f**king cheap man...has the right sump config you need too :D
https://www.sau.com.au/forums/topic/160742-jz-ceffy/page/2/#findComment-2996186
i found these sites, you might be able to contact them for more info.
http://www.nissansilvia.com/forums/index.p...howtopic=139528
http://www.grandprixgroup.com/gpi/magtuned...asp?news_id=769
there is a next one but i cant find it, if i do i would post the address
https://www.sau.com.au/forums/topic/160742-jz-ceffy/page/2/#findComment-2997032
what about it?
the inlet is no dramas whatsoever...as for the exhaust well a 1JZ has the dumps in the centre of the engine leaving you PLENTY of room for a decent front pipe and exhaust, if youre going a big single there shouldnt be any dramas either :thumbsup:
just asking because i wanted to know :laugh:
https://www.sau.com.au/forums/topic/160742-jz-ceffy/page/2/#findComment-2997776
some interesting info here. ive been wanting to do a 2jz cefiro conversion for quite a while now, but have been told by people (who arent very credible mind you) that it will cost an arm and a leg. may there just jealous :laugh:
given that it drops straight in, and ive even been told u can use standard mounts, and the loom is available, i cant see how hard it could be?
im not including labour mind u, im a cheapass d.i.yer as well
https://www.sau.com.au/forums/topic/160742-jz-ceffy/page/2/#findComment-3024641
some interesting info here. ive been wanting to do a 2jz cefiro conversion for quite a while now, but have been told by people (who arent very credible mind you) that it will cost an arm and a leg. may there just jealous >_<
dude you cant use stock mounts...you need to buy the 2Jizzle mounts...
loom for swap is expensive and not worth it...get an aftermarket comp and be happy :(
https://www.sau.com.au/forums/topic/160742-jz-ceffy/page/2/#findComment-3024908
    • Does anybody know the weight of the flywheel for the Nismo twinplate coppermix clutch kit for bnr34 over the standard flywheel? Is it a dualmass flywheel like oem or single mass?
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
