>> ### 1990 Cefiro ### <<
1990 Cefiro
Asking Price:
$10,000ono
Killometer's:
207xxx
Manual or Automatic transmission:
5 Speed Manual
Engine Type:
RB20DET. Although the car has done 207xxxk's, the engine was changed in Feb 2005 just prior to me purchasing the car. Engine swap was done by Dr Drift and hasn't missed a beat in 2 years!
Modifications:
AVS wheels
Tein Coilovers (Front left knocking, also comes with stock suspension)
GKTech FMIC
GKTech viper alarm system
GFB Bleed Valve @ 0.8bar
Apexi Pod
HKS oil cooler (not fitted but will come with car)
Spandex 40mm alloy radiator
Kaaz 2-way (only 8 months old)
Reinhard Catback Exhaust 3in > Twin 4in with removable mufflers and silencers!
Exteme HD clutch
BRAND NEW Nissan clutch master / slave cylinders (Nov 2005)
BRAND NEW bosch alternator (Jan 2007)
Darkest legal tint
JVC head unit
Blitz Turbo timer
Blitz boost gauge
Speco water temp gauge
Nardi Steering wheel
'Dildo' Shifter
Bride Brix drivers seat
Drift button (very important)
Items that come with the car:
Stock passenger seat (currently has CA18 S13 seat)
CA S13 drivers seat
Stock parts including SMIC, Grill, fan shroud, BOV etc.
4 stock rims from r31 (matte black)
Items that can be added for extra:
Defi din gauges
R33 5 stud conversion kit
Complianced:
YES. Came in under the SEVS rule ~2002 (have all papers)
Road Worth Certificate:
neg
Registration:
YES. VIC 10/2007
Crash History:
No major Accident History - Inspection Welcome
Other Comment's about the vehicle:
This has been my daily for the last 2 years, but I think its finally come time to part with it. Mainly due to going back to uni and also going overseas mid year which I need cash for ASAP.
Paint is a bit ruff, ie bog lifting where spoiler was removed and clear coat peeling on front left quarter due to bad paint job by the prev owner.
The interior is AWESOME! The carpet under the mats has never had a foot on it, which can be seen because it is PERFECT. I will be sad to see this car go, but its time to move on.
Contact detail's:
Ryan - (0412 033 449 or PM me)
Pics:
See ns.com link for pics: http://www.nissansilvia.com/forums/index.p...=0#entry3056138
Edited by konect
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
