Ok lads, we've been pretty slack with the whole SAU Qld part of things, so I need to know how many people are willing to help out with starting the QLD arm and who is willing to join the club.
I probably should have started a little earlier but being so far away from you all makes things a tad difficult.
So who's in...
https://www.sau.com.au/forums/topic/1608-sau-qld/
  • Replies 50
Well I was hopeing to have a chat with you and cam at the skidpan, i am really keen in getting this official, you're right we have been slack, and now with the NSW guys having already done it, we have no excuses about where to start.
I think we really do need to get everyone together in person to discuss it though, as online is a bit harder, although in your case squizz it is more then understandable.
Hopefully if we can at least get two or three of us behind it, we will get it going soon enough.
https://www.sau.com.au/forums/topic/1608-sau-qld/#findComment-31070
well der im in. we've still got the SDU QLD Member Register as well remember.
i'd like to continue my involvement at an official level if its suitable/required, but we can discuss this at the skidpan somewhat. we need to sort out what positions will actually be needed, and what their respective commitments will be.
an organised irc chat will be good for this.
remember - what we have is a GOOD THING. we dont want to over-officialise or structure this great relaxed social thing we have. SVD (in qld anyway) suffered its fate because of this and lack of members.
https://www.sau.com.au/forums/topic/1608-sau-qld/#findComment-31213
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
