Ok lads, we've been pretty slack with the whole SAU Qld part of things, so I need to know how many people are willing to help out with starting the QLD arm and who is willing to join the club.
I probably should have started a little earlier but being so far away from you all makes things a tad difficult.
So who's in...
https://www.sau.com.au/forums/topic/1608-sau-qld/
  • Replies 50
Well I was hopeing to have a chat with you and cam at the skidpan, i am really keen in getting this official, you're right we have been slack, and now with the NSW guys having already done it, we have no excuses about where to start.
I think we really do need to get everyone together in person to discuss it though, as online is a bit harder, although in your case squizz it is more then understandable.
Hopefully if we can at least get two or three of us behind it, we will get it going soon enough.
https://www.sau.com.au/forums/topic/1608-sau-qld/#findComment-31070
well der im in. we've still got the SDU QLD Member Register as well remember.
i'd like to continue my involvement at an official level if its suitable/required, but we can discuss this at the skidpan somewhat. we need to sort out what positions will actually be needed, and what their respective commitments will be.
an organised irc chat will be good for this.
remember - what we have is a GOOD THING. we dont want to over-officialise or structure this great relaxed social thing we have. SVD (in qld anyway) suffered its fate because of this and lack of members.
https://www.sau.com.au/forums/topic/1608-sau-qld/#findComment-31213
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
