Car: 1996 R33 S2 Gtst m spec manual
Colour: gunmetal gray/purple (anyone know what the colour is called?)
Mods: 19" RS GT rims, tein coilovers, recaros, alpine stereo and some smaller mods.
Msn: aztec_rose_1987@hotmail.com
I had a sss pulsar and a wrc celica and decided to sell both for a skyline. I have had the 33 for 3 months now. She was stock when i got it so its coming along nicely and faster than what i thought. Hope to meet up with you soon guys!
Hey all
Im brand new and know non of you s but i guess i will later down the track. Many little projects goin on but my main one is tryin to milk 500hp from my R33 Gtst. Might of scored a GTR so R33 project has stopped for now. Currently in central queensland but want to get down to the coast to be with the beautiful people
woah a 19 yo female in tanah merah
im a 19 yo make in tanah merah. pm me yo lol..
where bouts u live.? tanah merah ave.? i think ive seen ur old celica down the avenue.
anyway pm me yo
anyway pm me yo
dude this isnt boost or cb.
Cars: 2000 R34 GT-T , 1990 Chaser JX81, 1999 Audi RS4
Colour : Lighting Yellow , Pearl White
Mods: a few
MSN: nismo89@hotmail.com
Edited by 53XYN
Woot newbies thread found at last....
Cars: Mitsubishi FTO Turbo
Colour : Dark Blue, CF trimmings
Mods: $20k of engine work... CF Bonnet, 18" rims, Cream leather interior, etc
MSN: weirdkid_1@hotmail.com
yeah i know its not a skyline. But i was at the last meet with carlt and vish and the crew... Will be bringing along my baby when it gets back at the end of the month...
Hi to all...
newbies section! :(
Hi Im new :P
Cars: R33 Skyline
Colour : HyperSilver/2tone
Mods: why.. its Stock officer!
MSN: Pm me
I like stuff! ahoy there!.. dont forget support "ACt like a pirate day, In your area!.. Today!"
Hi all
Names Russell, I'm from Cairns in QLD
I have recently acquired 95 S1 R33 GTS-4 4 door N/A skyline. Shes in relatively good nick. I bought this as my tinkering car, so far theres no engine mods, there has been some suspension mods plus shes sitting on 18" amg mags. So i have a bit to play with :D
At the moment the poor girl is slow as all hell, my other car which is a 3L V6 Camry (I have modded the intake and exhaust on the Camry but thats all) leaves the skyline for dead, But i am hoping it might be because one of the previous owners of this skyline has put a 3 or 3 1/4 inch exhaust kit on a N/A setup, kinda sounds like shit and has no balls on the low end. So i am having a 2.5in pipe put in, hopefully it will help that problem. I would think about turbo, but not quite yet i need to learn my skyline first. After driving a FWD car for a few years this is all a new experience.
So atm I know nothing and could probably not offer any advise and Ill be asking a lot of questions, so bare with me. :action-smiley-069: So far I have found quite a bit of information from just browsing SAU.
Cheers
Hey every one iam from bundy and have just picked myself up a stock s1 r33 i have big plans 4 my baby with 400r body kit full respray is a blue and silver and would like to get 350hp at the wheels on 12psi witch should be easy at the moment i am after a good cheep 600x300x76 intercooler and pluming if any one can help with good places to buy would be grate
thanks andrew
Hope to see some of you guys when i am down the gold coast in 3weeks time
'Bout time I get around to doing this.
Cars: NA R34 Sedan
Colour : Silver
Mods: There have been somethings added, somethings swapped, and somethings piggy backing other... :bunny:
Number Plate : Stock 830 JXU (that's stock for now... (But it's easier to spot the GT wing on the back...))
MSN: Pm me
Hi everyone.
I picked up my white '98 R34GTt 2door a couple of weeks ago.
Its completely stock except for suspension and a japanese GPS/TV/Everything head unit that cant be changed to english
stock plates [626-KJV]
Live on the Sunshine Coast (most likely to see me in maroochydore or coolum)
Hi
Im Daniellive in gympie qld. have a white r33 skyline with stock motor and a gt3076r turbo has 336hp atm with stock injectors.more pwr to come. So see you out crusing number plate Pink or red UCD15 not hard to spot me in a crowd
Hi
Im Daniel live in gympie qld. have a white r33 skyline with stock motor and a gt3076r turbo has 336hp atm with stock injectors.more pwr to come. So see you out crusing number plate red UCD15 not hard to spot me in a crowd.
Dan
  nissanskyrice said:
Hi everyone.
ahha i like ur name.. skyrice..
welcome to the forums
    • Hi All, New member here, I've joined to help my son with an issue that is truly doing our heads in. I'll start with a bit of an overview. Chris carried out some modifications to the engine to try and extract just a little extra power out of the motor and make it a bit more efficient. Previous to this work, the car already had an upgraded exhaust, increased boost up to 14psi, modified standard turbo to metal impellers and slightly oversized, upgraded fuel pump, been dyno-tuned at JEM, and some other bits n bobs like coil packs etc. Before the current mods it was making 236rwkw at 14psi but after the new mods it now makes 209rwkw at 14psi. The work he carried out is as follows, timing belt service, water pump replacement, return to sump radium catch can, had oem head rebuilt and machined 0.2mm, fitted Athena cut ring head gasket 1.2mm thick, arp 2000 head studs, added rear prp head drain, added an external wastegate 40mm turbosmart welded off the stock manifold and plumbed back into a 3in dump. The car has been on the dyno and apparently the ignition is working, fuel flow and fuel pressure is fine, injectors are fine, spark plugs are working fine, Maf is working, O2 sensor is working, TPs sensor is working, VCT is working, CAS is working, boost leak test showed no boost leaks, compression test first crank cold 135psi and got to 150psi across all cylinders once cranking, timing is confirmed at tdc with a dial gauge and the cam dots line up, no blockages in intercoolerm throttle body or pre-turbo intake, no blockages in exhaust, cat conveter or down pipe, turbo looks fine and spins and wastegate looks fine and is new. Soz for all the detail but after all this, it has been in 3 times for dyno and each time comes back stating it's not going to make power. After the first (or second, can't remember now) trip to dyno we did find the timing out by one tooth and this improved things, but it is still well down. Does anyone have any ideas?  Any replies much appreciated as we're just not sure of which direction to take this. Regards Rob (Chris's Dad).
    • That's just a gauge, with a certain amount of electronic damping, and no-one cares if it is timely-accurate. I'd hesitate to use it for an ECU MAP input without knowing that it was a nice signal. Responsive but smooth. Not laggy. Not lumpy.
    • Took the dirty BMW to an actual drag meet so I could do a legit full pass on a sticky enough track and had a quiet goal to try and beat my PB in the old R33 GTS25t The time to beat:  R33 on stock RB25, Internal gate GT3076R on stock manifold tuned to about 17psi on BP98 and running on drag tyres: F20 M135i with intake, dump pipe and MHD OTS Stage 1 tune on street tyres - didn't even drop the tyre pressure: Kinda similar, and kinda way different
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
