Although im on the SAU QLD site I never come on here so....
HI!
Car: M35 Stagea
Im always driving (part of my job) anywhere north of the river Brisbane up to Rockhampton area in the Stagea.
Jason from the Gold Coast. Drive an R34 25 GT 2000 Skyline.
Fairly noticeable with the P plates.
I'll include some pics!
Cya
Hi Jason,
Welcome to the group!
Great to see some new blood in here. :)
The GT2000, was that the RB20 or RB25?
Look forward to meeting you at an event! We do have a co-cruise with the Z boys on Sunday, would be great to see you there.
Ciao!
Tony
Hi Jason,
Ciao!
Tony
Sorry I haven't got around to replying - I work Satudays and Sundays!
It's a shame because this is when, so it seems, you guys have all the cruises. Unlucky!
Would be fantastic to get some time off and come along.. I managed to get another shot at Surfer's Paradise beach this morning which I'll post up later.
  • 4 weeks later...
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
