Hey guys after popular demand we have a PB section to be permentlly stickied...
Please use the template below for posting your results, this will help for quick reference...
(Please no chat in this thread just use the template and discuss via pm if need be, this is like a bit of a hall of fame)
Car:
Turbo:
Tyres:
Date:
Time:
Output in rwkw:
Track:
Air Temp:
Track Temp:
Humidity:
Reaction time:
60ft:
330ft:
660ft:
1000ft:
ET:
MPH:
Comments:
https://www.sau.com.au/forums/topic/160847-drag-strip-pbs/
Oh oh me first...
Car: R33 S2 GTS-T
Turbo: GT30 High Mount with external gate
Tyres: 255/40/17 Yum-Cha's @ 30psi :rofl:
Date: 03/03/07
Time: 4:40pm
Track: Willowbank
Output in rwkw: 300+rwkw
Air Temp: 27 Deg
Track Temp: 40 Deg
Humidity: 65%
Reaction time: 0.944
60ft: 3.001
330ft: 7.085
660ft: 9.306
1000ft: 11.366
ET: 13.369
MPH: 121
Comments:
Was a poor run, its the best official run I have had to date. I had wheel spin until 3rd gear, I could not launch the car and at a 120mph pass it could have been as good as a low 11. I will be buying a slick tyre before my next run at the drags. As you can see by my 60ft time, to even run a 13 with a 3 second 60 ft is pretty good. Most 3 second 60ft'er would run a high 16 quarter so it shows how quick it pulls once traction is achieved...
I should also add, I had a bad batch of fuel and fouled plugs and the car was pinging pretty badlly at the top end of the track and the engine check light flashed a few times with a knock level of 96 which is bad, but it was the fuel as the very next day I filled back up and cleaned the plugs and no problems at all...
Later the same night I ran a 131mph and recieved a warning about my speed, but the et was even worse, it was like a 14 second quarter with a 4 second 60ft time...
So as I said, its now time to spend some money on getting that power to the ground and breaking into the 11's then with fine tuning a 10 is possible... :rofl:
https://www.sau.com.au/forums/topic/160847-drag-strip-pbs/#findComment-2987082
Car:1996 R33 GTST series2
Turbo: standard turbo @ 16psi with 3" zoorst, pod, malpassi, microtech and shit tyres
Date: 19 April 2006
Time: 6:02pm
Output in rwkw: 212rwkw
Track: Willowbank
Air Temp: 25Deg
Track Temp: 32Deg
Humidity: 70%
Reaction time: 1.077
60ft: 1.99
330ft: 5.790
660ft: 8.864
1000ft: 11.515
ET: 13.790
MPH: 91.67
Comments: My launcnh was pretty stuffed due to shitty tyres, but it gave me a base for improvement. I went again later that year with the same setup and got the same result, the time slip was rumpled up, so I tried ironing it so my scanner could read it, but the paper is heat reactive and it blanked it lolz.
https://www.sau.com.au/forums/topic/160847-drag-strip-pbs/#findComment-2987088
Car: 1992 R32 GTR
Turbo: Stock Turbos
Date: 17/03/07
Time: 6:58pm
Track: Willowbank
Output in rwkw: Approx 185
Air Temp: 23 Deg
Track Temp: 35 Deg
Humidity: 64%
Reaction time: 1.124
60ft: 1.922
330ft: 5.533
660ft: 8.542
1000ft: 11.118
ET: 13.315
MPH: 102.86
Comments:
Finally got my starts a little better. Sitting on about 5500 RPM at launch, quick side step of the clutch (thanks Noel :huh:) and off I went. I think it has a little more in it. Next time will side stepping it at 6500 rpm. Hopefully good for 13.1. Was a little worried at 5500 rpm as on my last two runs the old clutch wasnt handling it too well. I dont blame it though, being a dead stocker. Turned out alright though, once the car was cool the next day there was no worries. Look forward to next time, will be a Wednesday night though.
https://www.sau.com.au/forums/topic/160847-drag-strip-pbs/#findComment-2987701
Car. R33gtst
Turbo. stock
date. 17/3/07
time. 8.17
Track. Willowbank
Output. 173 rwkw
temp. 23 degrees
track temp. 34 degrees
humidity. 72%
Reaction time. 0.621
60 ft. 2.06
330 ft. 5.834
660 ft. 8.955
1000 ft. 11.617
et. 13.869
mph99.25
Comments. My best run of the night but my mph was down by about 3mph. Maybe i backed off a bit early. I couldnt break the 14 second barrier due to bogging at the line so i upped the launch revs to about 4800 and it stuck. The track did seem sticky as, Hope it stays that way
https://www.sau.com.au/forums/topic/160847-drag-strip-pbs/#findComment-2987725
Car: 1990 GTR32
Turbo: GTR34 N1 x 2
Date: 23rd Sept '06
Time: 1:41pm
Output in rwkw: 315rwkw @ 1.2bar
Track: Willowbank
Air Temp: 47degC
Track Temp: 45degC
Humidity: 45%
Reaction time: 1.029
60ft: 2.098
330ft: 5.636
660ft: 8.461
1000ft: 10.822
ET: 12.842
MPH: 113.21
Comments: First time ever draggin'. Screwed up launch. On 18" wheels. Will definitely try to improve on time next time. :huh:
Edited by J-Boy
https://www.sau.com.au/forums/topic/160847-drag-strip-pbs/#findComment-2987727
Car: 97 R33 GTST sedan
Turbo: Standard
Date: 14/10/2006
Time: 5.48pm
Output in rwkw: 150rwkw
Track: Willowbank
Air Temp: 20 C
Track Temp: 30 C
Humidity: 68%
Reaction time: 0.785
60ft: 2.131
330ft: 5.897
660ft: 9.008
1000ft: 11.667
ET: 13.930
MPH: 97.38
Comments: Have fitted a CES front pipe since doing this run, hoping for another tenth or so next outing.
https://www.sau.com.au/forums/topic/160847-drag-strip-pbs/#findComment-2993542
Car:R32 GTR
Turbo:Old style N1s
Date:6/5/06
Time:6:47 pm
Output in rwkw:About 300
Track:Willowbank
Air Temp:22 degrees
Track Temp:27 degrees
Humidity:55%
Reaction time:0.705
60ft:1.863
330ft:5.010
660ft:7.626
1000ft:9.845
ET:11.702
MPH:122.25
Comments:Run on 17" Falken Azenis 215s, reved to the limiter and side step the clutch ( which sliped all through 1st ) ! 4wd makes it all too easy :)
https://www.sau.com.au/forums/topic/160847-drag-strip-pbs/#findComment-2999266
  • 3 weeks later...
Best overall Timeslip:
//Update - I ran a 12.93 on this same setup a while back, will see what the new one gets...
Car: R32 GTR
Turbo: Twin R34 GTR stockers
Date:06/04/07
Time: 7:37 pm
Output in rwkw:210
Track:Willowbank
Air Temp: 18 degrees, Intake temps at the manifold were 42 degrees solid all night. Intercooler is clogged chock full of bugs since I washed the car over 2 months ago...
Track Temp:30 degrees
Humidity: 72%
Reaction time: 0.721
60ft:2.107
330ft:5.784
660ft:8.859
1000ft:11.465
ET:13.643
MPH:103.69
Comments
Other times of note that night:
Highest MPH was 104.41, reaction went down steadily and on my last run was 0.484, best 60ft was 2.102 and worst was 2.187, other two times of the night was a 13.690 and a 13.678, so ever run was a 13.6 which is quite consistant. DYOT events here I come! Tyres were dodgy street tyres id fu*ked at QR the week before and boost was bone stock, so with a bit of boost and good tyres I should see some lower 13's.
Runs were against a holden v8 with lots of work which destroyed me running an 11 however I still ran my pb, tim's (booosted33) R33 GTST and a factory bone-stock XR8 which i beat by 1.569 seconds.
https://www.sau.com.au/forums/topic/160847-drag-strip-pbs/#findComment-3034256
Turbo: Standard
Tyres: Federal SS595 255/40/R17 @ 36psi
Date: 11/04/2007
Time: 8.55pm
Output in rwkw: 150rwkw (allstar dyno day *see note)
Track: Willowbank
Air Temp: 17 C
Track Temp: 29 C
Humidity: 87%
Reaction time: 0.522
60ft: 2.117
330ft: 5.828
660ft: 8.911
1000ft: 11.548
ET: 13.772
MPH: 101.37
Comments: Got the extra couple of tenths I expected from fitting the CES split front/dump pipe and metal 3" cat to replace the standard front/dump pipe and gutted 2.5" cat the car came with. I think I can get it down into the low 13s with some mickey thompson street drag radials. This shall be my next purchase for bettering my 1/4 time. Not bad for K&N panel filter, full 3"exhaust, 10psi and 100mm thick SMIC. Who needs a front mount! :)
*Really beginning to doubt the all star dyno reading now, having an ET of 101mph, that was the same ET as I used to get in my old GTR with 200 awkw. . . . . GTRs don't weight THAT much more. . . . . . ETs don't lie. I suppose I was the first on the dyno and with readings of 92rwkw, 96rwkw, 121rwkw and finally 150rwkw, how would you know what my car is actually getting?? Not impressed by that day still. . . .
https://www.sau.com.au/forums/topic/160847-drag-strip-pbs/#findComment-3043180
Car: R33 GTST
Turbo: Slide high-flow
Tyres: Federal SS595 255/45/17 @ 18psi
Date: 21-4-07
Time: 9:14pm
Output in rwkw: 215 according to the Allstar dyno......
Track: Willowbank
Track Temp: 29 degrees
Humidity: 1016mB
Reaction time: .908
60ft: 1.893
330ft: 5.6
660ft: 8.59
1000ft: 11.1
ET: 13.16
MPH: 110.4
Comments: Was running mid 13's all night and finally put a solid run together on the last of the night. Pretty sure there is a 12 in it with more practice. Thanks to Fineline for some salty sea dog drag racing tips :(
https://www.sau.com.au/forums/topic/160847-drag-strip-pbs/#findComment-3065542
Car: lancer evolution 3 gsr
Turbo: tdo5 big 16g standard
Tyres: fedral 595 205/45/17 at 36psi
Date: 15/04/07
Time:1.12pm
Output in rwkw:??? nfi
Track:willowbank
Air Temp:24
Track Temp:42
Humidity:46%
Reaction time:.951
60ft:1.71
330ft:5.332
660ft:8.299
1000ft:10.826
ET: 12.92
MPH: 110.48
mph is good for a low 12 high 11 and racing in the middle of the day doesnt help
Edited by evo201
https://www.sau.com.au/forums/topic/160847-drag-strip-pbs/#findComment-3072472
Car: Datsun 120Y, RB20DET auto
Turbo: Garrett GT35R
Tyres: 205/50R15 M/T street radials
Date: 15th April 2007
Time: 12.35pm
Output in rwkw: Last dynoed with 187rwkw but probably around the 210kw mark now.
Track: Willowbank
Air Temp: 23deg
Track Temp: 36deg
Humidity: 50%
Reaction time: 1.28
60ft: 1.54
330ft: 4.47
660ft: 6.99
1000ft: 9.19
ET: 11.08
MPH: 118.45
Comments:
I am really happy. Everything went the way it should have.... Next step, 10's
https://www.sau.com.au/forums/topic/160847-drag-strip-pbs/#findComment-3075153
Car: R33 GTST
Date: 03-05-07
Time: 11:05pm
Track: Willowbank
Air Temp: 16 degrees
Track Temp: 25 degrees
Humidity: 1015mB
Reaction time: .597
60ft: 1.841
330ft: 5.36
660ft: 8.22
1000ft: 10.68
ET: 12.70
MPH: 112.3
Comments: No changes since last run, just practice :)
https://www.sau.com.au/forums/topic/160847-drag-strip-pbs/#findComment-3096069
Car: 1JZ Cressida
Turbo: stock twins
Tyres: Bridgestone RE92 205/65/15 burnout tyres
Date: 15 april 07
Time: 13.406
Output in rwkw: 210rwkw {dodgy dyno i reckon}
Track: WB
Air Temp:
Track Temp:
Humidity:
Reaction time: 2.190
60ft: 1.917
330ft: 5.529
660ft: 8.559
1000ft: 11.191
ET: 13.406
MPH: 102.11
Comments: previous to that day i had run 105mph, but mph was down due to hot day and/or slipping auto, have also run a 1.895 60' but mph was down causing a 13.51
only has dumps, cooler, exhaust, 15psi and now a 2800rpm stallie
https://www.sau.com.au/forums/topic/160847-drag-strip-pbs/#findComment-3102171
Car: 1986 nissan navara dualcab with stock ca18 fmic
Turbo:stock t25
Tyres:235 45 17
Date:09/05/07
Time:7:02pm
Output in rwkw:hasnt been dyno'd yet
Track:willowbank
Air Temp:19
Track Temp:28
Humidity:77
Reaction time:1.213
60ft:2.460
330ft:6.798
660ft:10.391
1000ft:13.515
ET:16.149
MPH:85.45
Comments:first time down the strip, happy with how i went, need practice though
https://www.sau.com.au/forums/topic/160847-drag-strip-pbs/#findComment-3107510
Car: R33 GTST
Tyres: Federal SS595 255/40/17 @ 18psi
Date: 16-05-07
Time: 5:39pm
Track: Willowbank
Air Temp: 21 degrees
Humidity: 1018mB
Reaction time: .782
60ft: 1.73
ET: 12.58
MPH: 111.3
https://www.sau.com.au/forums/topic/160847-drag-strip-pbs/#findComment-3122652
  • 3 weeks later...
Car: r32 gtr
Turbo: stock everything except zaust + pods
Tyres: maxxis
Date: 17 March 2007
Time: 8:25pm
Output in rwkw: ? approx 200awkw
Track: Willowbank
Air Temp: 27degC
Track Temp: 33degC
Humidity: 73%
Reaction time: N/A wasn't going for reaction, just learning about the car
60ft: 2.049
330ft: 5.628
660ft: 8.599
1000ft: -
ET: 13.225
MPH: 106.89
Comments: that was the best of 3 runs (the second one on the night/then the clutch died! hehe, but fun learning the vehicle- going again soon WOOHOO)
https://www.sau.com.au/forums/topic/160847-drag-strip-pbs/#findComment-3162562
Car: R34GTT (4dr)
Turbo: Hi Flo GT30 Core
Tyres: MT's Semi Slicks
Date: 15-06-07
Time: 9.45pm
Output in rwkw: 238
Track: Calderpark
Air Temp: N/a
Track Temp: N/a
Humidity: N/a
Reaction time: 1.066
60ft: 1.858
330ft:
660ft: 8.126
1000ft:
ET: 12.633
MPH: 109.56
Comments: Happy But still think I can go quicker by about 0.2, 0.3..........
https://www.sau.com.au/forums/topic/160847-drag-strip-pbs/#findComment-3181783
Car: R32 GTR
Turbo: GTR34 N1 twins
Tyres: 235/40/18, 265/35/18 Dunlop DZ02G
Date: 21/06/07
Time: 7:43pm
Track: Willowbank
Output in rwkw: 300+awkw
Air Temp: 10 Deg
Track Temp: 15 Deg
Humidity: 52%
Reaction time: 2.308
60ft: 1.796
330ft: 4.963
660ft: 7.629
1000ft: 9.875
ET: 11.795
MPH: 119
Finally i got my ass into the 11s on my 2nd time out on the dragstrip. I still suck at launching though. This was prolly my better launch. Cuz later i did a 12.089 @ 124mph, if only i could have gotten a good launch on that one! But well i guess with more practice, i could do my car justice by putting it into the low 11s. Overall im satisfied, especially since i run on 18s.
https://www.sau.com.au/forums/topic/160847-drag-strip-pbs/#findComment-3192099
    • 2 spots that my exhaust guy joined the 2 pipes together  Made a big difference. I'm now able to live with it. I can make it louder if I want by removing the HKS caps.
    • Hi all, considering clutch upgrade to support 1130 engine hp from 1650cc injectors on e50 at 85% duty cycle (1650 x (11.85/14.7) x 85%). Narrows down to these three as they can be converted to use gm 26 spline input shaft if I ever want to use transmission with that input shaft (orc1000f and r3c easy/cheap just change center hub; tr2cd pricier must change clutch discs). Pricing orc1000f similar to tr2cd, r3c about usd 200 pricier. Orc1000f triple plate 200mm. Tr2cd twin plate 215mm. R3c triple plate 215mm. Claimed max torque : orc 1000f 723 lbs ft; tr2cd 800 lbs ft; r3c 1100 lbs ft. Why orc1000f triple plate but claims lower max torque vs tr2cd twins? Is orc1000f underrated? Any info maxing out these clutches? Info on street/traffic driveability/pedal feel? Thank you for any info on them.
    • Some troubleshooting, connect up a timing light/gun with a proper ignition lead on coil 1. Hold the revs at 4~4500rpm and see if your timing is all over the shop, scattering off its tits. If so, there's a high chance your CAS is fked. But I read you have a Link ECU ready to go in, why not just skip all this and put that in - will make troubleshooting so much easier.
    • Misfires when the car is fully warm are generally attributed to the coils (and/or the igniter, on cars with a separate igniter). They can stop working properly when they get hot for a number of reasons. Either electric/electronic, or from thermal expansion opening up gaps and allowing HV leakage. Seeing as you have replaced the coils, that could/should rule them out. But I wouldn't always assume so. Were the coils genuine? Or is there a chance you have bought some counterfeit Chinesium shit? Then we're back onto loom connections. They can fail when warm/hot for the same reasons. Inspections, cleaning of contact surfaces, ensuring that terminals are fully inserted, etc etc, are all justified. The same (heat effects) holds true for the other electrics and their connectors. AFM & CAS, primarily. If you try that Chinesium AFM, drive it around on low load until it is properly hot, but do'nt give it more load than you have to, except when you need to see if it will still miss. I'm dead serious about the untrustworthiness of the calibration of those copy AFMs. Injectors are unlikely to get hot unless the fuel is coming back around hot. You could try squirting them with compressed air or freeze spray to cool them back down to see if they are maybe the cause.
    • Alright, all the plugs looks good. Noticed that it starts to get bad when the car is up to temp, that's when things starts to misfire hard. next to do is Injector cleaning and such. Got in touch with a shop to do work on the injectors next Monday also help on diagnosis.
