Its that time again!!! Turbo has shat it self............. so im looking at doing a decent upgrade. Im not to sure what i should be going for and i was looking for feed back/advice on what other people are running and what power figures they are getting. Currently im running stock turbo and i use the car for drift.
Any help appreciated!!! :rofl:
Edited by -SKYLINE-
https://www.sau.com.au/forums/topic/160863-turbo-upgrades-to-rb25/
The slide turbo's appear to offer a cheap excellent value upgrade.
I couldn't bring myself to spending 2k on a GCG highflow for only 250rwkw odd. Spend another couple hundred and throw a tidy little GT3076r 500hp turbo on the side of it, thicker headgasket, 20-22odd pounds of boost and you'll have a damn good attempt at cracking 300rwkw. :rofl:
Shaun at Boostworx doesn't have issues having the rb25's holding together at such power levels/boost so it may be worth speaking to him to see what he recommends with regards to your spool expectations etc.
depending on what horsepower you want, when you want it to hit full boost, what mods you have done to your engine already
determine what turbo you should choose, i suggest you see an expert.
cause you dont want to waste all your money on something thats not going to suit your aplication
thats just what i think
I got my GT3076R turbo recently from ATS (Adelaide Turbo Services) and its going extremely well. Havent had a single issue yet and it looks extremly tidy and has stock appearance. Of course for now I have gone the option of using a Rb25 stock exhaust housing for the turbo but once I decide to get more power and redo the dump I'll get a different one put on. @ the moment looking for ~240kw or so before my engine shits itself then I'll have my own crack at 300kw with a different setup on the same turbo.
Paul, did you end up having the std compressor housing machined up to suit or did Bill simply use the gt30 comp cover and run a silicon elbow to the ic piping?
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
