Item: Mitsubishi Cordia
Website: n/a
Item Condition: pretty good, only very slight dint/graze
Reason for Selling: wanting something newer (wrx or r33 probably)
Price and Payment Conditions: 8000 ono (will swap with cash on top for car of interest).
Extra Info:
~~~NSW Fully Engineered~~~
1985 AB
Single cam 4g63
Fully rebuilt (about 8000kms done)
balance shafts removed
ACL race bearings
balanced/blueprinted
Custom billet cam shaft
Adjustable vernier cam gear
Custom 60thou forged wiseco pistons
Ported/polished head
ARP head studs
Cometic head gasket
Compression test just done with 150p.s.i in all cylinders
EMS Dualsport ecu with hand controller (Just had computer upgraded for laptop access too) mouted in dash
M&W direct fire ignition
heavy duty leads
Sard 600cc injectors
Sard fuel pressure regulator
Custom fuel rail
Bosch 044 fuel pump
Hyundai intake manifold
XF throttle body
custom polished intercooler piping
PWR silicon hose joiners
HKS air filter
Custom made front mount intercooler
Blitz KKK 3070 550HP turbo
Tial external wastegate
Screamer pipe
Turbosmart boost controller
Turbosmart type 3 Blow off valve
Custom made exhaust manifold and dump pipe
3" mandrel bent exhaust turbo-back with cannon style muffler
Custom PWR radiator
Custom made Heavy duty Jim Berry clutch
Genuine speedflow braided fittings throughout
oil catch can and breather from intake pipe
Custom made strut brace
Lowered on pedders springs
17x7" white wheels (near brand new tyres)
new wheel bearings
VR4 rear brake upgrade (disks all round)
paint and body is pretty much perfect
Interior is very very good
White dials
3 x Autometer gauges mounted wher centre air vents are on custom laser cut metal panel
SAAS steering wheel
turbo timer
Recaro passenger seat from evo
Pioneer cd/mp3 player
6" round pioneer speakers mounted in doors
6 x 9" pioneer speakers in parcel shelf
Dark tinted windows
can also include some spare parts.
Pictures: http://www.brokendesignz.com/customcordia.html
Contact Details: PM
https://www.sau.com.au/forums/topic/160876-mistubishi-cordia-fs/
170kw atw on 16psi boost. Turbo's more efficient at higher boost (bout 25psi) and engine can handle it..... but 170kw for a 1000kg car's enough for me at the moment :unsure: If i keep it, would probably have another map for higher boost made.
Bump.
Parts on this car are worth a mint, however: willing to drop the price a bit if it sells quick. Please make an offer if interested, am after a quick sale so i can move onto a newer car.
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
