All prices are guesswork, no reasonable offer refused, PM me with your price. No stupid offers, but I am ready to bargain.
If you want a detailed pic of an item ask and I'll do it.
Postage extra, not pickup unless your in Riverina NSW [or want to drive here].
Steering column inc. lock and key $50
Auto shifter $20
ABS + steel piping $100
Motor fan $50 SOLD
Master cylinder + booster $100
Air cond. fan + housing SOLD
Air cond. condenser under dash unit $30
Air cond. compressor $50 SOLD
Air cond. mixer dryer unit $20
Both blinker and lights/washer stalks $10 each
Washer bottle $10 SOLD
Overflow bottle $10
Wiper arms $10 each
Wiper motor $15
Accelerator pedal + cable and mounting $20
Brake pedal + mount for auto $20
Fuel filter $10
Dash grill with sensor l/h only $5
Glovebox and side $20
Instrument surround SOLD
Kickpanels both l/h and r/h $10 each
Heater core $10 SOLD
Both l/h and r/h stone gaurds for under front mudgaurds $20 each SOLD
Front pipe $40
See my other sale at http://www.skylinesaustralia.com/forums/98...ml#entry2855326
https://www.sau.com.au/forums/topic/160884-left-overs-from-an-r33-half-cut/
lol you pm'd with with only an answer of where the ficticious royston vasey is and where i could possibly buy it on dvd! lmao
where are you really located?
DA21, no leaks afaik. I never tested it, I don't know how many k's, it doesn't leak water or air in a hand held test.
It looks like a serviceable unit.
  • 4 weeks later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
