I have the same turbo's.....I though the same as you.
The turbo's sounded like they were fluttering......but all is normal.
Get a tune and wait a little while.
I don't notice this anymore on mine..either the surges have gotten softer
or I have got use to them.
  • Replies 54
I'm curious how tuning can fix it too. I assume that the surge you guys are talking about is when you very slightly back off the throttle, it flutters and the car sort of shudders. my S14 does that too and i wanna get rid of it.
I believe the intake wheel of the Turbo slows down when you back your pedal off or change gears.
The excess amount of air is pushed back onto the incoming air it has tried to create.
Thus causing fluttering, the longer you drive around the softer this sound becomes.
the harder you push the car...the better the sound becomes
from my knowlege it occurs when the engine is on load and throttle is half backed off
so to me it sounds like the bov's are half opening so pressure is vented back into the front of the compressors
and some how causes it to either surge or vary excessively which gives the compressor flutter / chop chop noise
confused how tuning would fix it, even though it does
I don't think the tune actually fixed mine,it was their after the turbo's where fitted and tuned......and went away slowly.
Does the AVCR boost controller learn from excessive flutter and driver behaviour?
I have an AVCR boost controller...and seeing that it creates/controls boost it can also slow the spikes...maybe.
I wonder if the boost controller is controlling my flutter?
Just my 2c
i doubt it would tekin
i would be surprised if it would
most controllers are purely interested in build a good ramp for boost build and keeping it stable
im not even sure it would see the bouncing pressure
go for a drive and replicate it, let us know
does boost pressure bounce? i bet it doesnt
I am just trying to figure out why it has gone away on mine....
Are new turbo's tighter in the wheel construction?
Do you need to break in a Turbo....get it to loosen a little maybe.
Has anyone had this thing on anew turbo that has slowly gotten quieter?
Or is it as I had stated....you just get use to the noises...
actually it makes a bit of sense if it is seeing the pressure vary
cos then it would close and open its solenoid based on pressure
so the turbine would speed up quickly as the gate would close
then it would open again, like rapid chatter
try it and let us know if the boost varies rapidly (as in the controller display)
plot BOOST on analog chart display and see what it looks like
getting more air into the cylinder rather than having it revert should be the key.
changes to cam gears could/should help.
exactly why tuning beats me. i spoke to a few tuners that feel it can be difficult to get around but others seem to think it is no problem. so i imagine the degree of mismatch of the turbine/compressor wheels might make this easy or near impossible.
and these turbos are not mismatched.
Edited by wolverine
there is no such thing as wastegate flutter
remove the phrase, it does NOT exist, there is no such thing
im curious how the tuning can correct this
Ok so what do you call it when the wastegates go chu,chu,chu,chu and the car surges and carries on? please elighten me. I've already ruled out the BOV's as I said earlier.... I'm confused
Hey everyone, I just finished fitting the GT2860-5's to my R32 gtr and must say they've made a huge difference, the car feels more responsive and comes on boost earlier too. On full throttle it's fine but on really light acceleration and at cruise I now get bad waste gate flutter and surging. I never had this problem with the original turbo's and haven't changed anything other than the turbo's and a bit of metal off the exhaust manifolds.
Any ideas?? Help please!!!
Do you have a boost controller?
What make and model?
i dont understand how it can be a case of stuffing too much air into the cylinders
from what we know it happens when the engine is on some load (not max) and its up a hill
a hill usually brings on good engine load, which is great for boost building
but it happens when the user is on half throttle, not what i would call max throttle
at least, what i have read it occurs when its half throttle, and not max, is that correct?
paul this is exactly what i have experienced with an ordinary hi-flow of unknown origin.
light to medium throttle openings caused surge, WOT all good.
changes to tension of the BOV spring eased the symptoms, changes to tuning and cam gears cleared the issue.
its not the wastegate's fault, there is no such thing as wastegate flutter
its do with the bov's, i suspect they are half opening
and its causing a conflict with either the compressors or the actuators opening and closing rapidly
as pressure in the manifold varies rapidly
as simple as adjusting the duty cycle on the boost controller so its slow and progrssive would possibly cure it out
i suspect thats what most tuners do to correct it, make the solenoid open slow and in small increments instead of fast and hard
that way it doesnt induce open/close/open/close type behaviour, which dictates massive changes rapidly in manifold pressure
as the compressor is sped up and slowed down repeated really quickly
i also think there are two issues here (well maybe)
compressor surge of "fluttering" occurs when pressure past the compressor is beyond what the compessor can supply
ie:
workshop A hiflow and do whatever and you go and run the turbo
you dial in 15psi but forwhatever reason (mismatched combo, bad wheel, etc) then manifold pressure ramps to 22psi
the compressor wheel surge's as the pressure past the outlet is greater than what it can supply so it flutters/surge's
i would expect this problem to only occur at full throttle, wide open throttle and aggressive boost building / full load
the other scenario is the common after market twin turbo flutter / chuffing
which i think is a combo of the bov's half opening and venting back and then actuators opening/closing
in a harsh and on/off type fashion instead of soft and progressive.
this only occurs during light / medium load and usually up a hill is a good example of when it occurs
Hmmm, but I blocked the vacuum line to the BOV's off and tried it, and made no difference at all. And it's only on very light throttle right on the transition from manifold vacuum to boost that it occurs
The wastegate is located on the Turbine/Rear of the turbo
The surging is from the comressor wheel, which is on the Intake/front side of the turbo
Comp surge (the type we are talking about here) occurs when the turbos are flowing more air than then motor can handle
The air is coming from the compressor side, and has nothing to do with wastegate operation on the rear end of the turbo.
How it is tuned out, i am not sure. I'm yet to go across that in my travels
hmm well then im not sure
i cant see a reason why a new pair of turbo's would surge when going from vacuum to positive pressure
knowing what the tuners do to fix it could help give it away
maybe they just retard the timing a touch during boost build
that could help, but a bit of a poor mans fix maybe?
id love to know the cause
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
