Hello how is everyone?
I Bought this car around 6 months ago and i love it.
its a Purvis Eureka kit car made of fibreglass and is mounted on a VW chassis.i bet no one on the road would think this is a 4 cylinder 45kw car :P.
Engine:VW 1600cc
Weight:600kg
Wheels:14" bathurst globe
Height(from ground to roof):1m
Tell me what you all think and What licence plates would be good for this car :happy:
https://www.sau.com.au/forums/topic/160922-who-like-my-new-car/
they are nice kit cars - looks like it needs a bit of work - but once its looking mint, expect lots of heads turning.
MR2 engine will def go in nicely....rb25/26 would be better if it can fit and if u can put all the right parts in it - hell, you probalby dont even need a det or dett...just put a de - with 140 odd kws and 600kg it will fly! :P
edit: any interior pics?
Edited by emsta2003
Yes i have one interior pic but its with the seats removed and doesnt look that good but i will put it up.I was thinking of going rotary for this car but theres so much work involved so maybe down the line.Yes it does need a lot of restoration but then again i only paid $2500 for it :happy:
if its got a beetle motor a wrx engine or an EJ25 will be piss easy to install!
these are cool. use to be one in my area when i was young
I cant drive turbocharged car mate :P P plate restrictions.
Read an old magazine article on these years ago. Apparently the hydraulics failed in one of them and someone was stuck inside the car until they could do something about it. I can't remember the exact circumstances and what happened, but it sort of turned me off them.
Get an EJ20 or EJ25 non turbo then, they're a relatively simple engine to turbo later on if you wish, but even in non turbo form if you trick it up with an exhaust and intake it should have more than ample power to make that thing a ball tearer.
Edited by d0p3y
there are a few of them in town.
as for motor, you would need to see if the car has a engine size rating (the biggest motor you can put in that car). this would depend on state, etc.
yeh i think its 1.8L turbo or 2.5L N/A.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
