Hello how is everyone?
I Bought this car around 6 months ago and i love it.
its a Purvis Eureka kit car made of fibreglass and is mounted on a VW chassis.i bet no one on the road would think this is a 4 cylinder 45kw car :P.
Engine:VW 1600cc
Weight:600kg
Wheels:14" bathurst globe
Height(from ground to roof):1m
Tell me what you all think and What licence plates would be good for this car :happy:
https://www.sau.com.au/forums/topic/160922-who-like-my-new-car/
they are nice kit cars - looks like it needs a bit of work - but once its looking mint, expect lots of heads turning.
MR2 engine will def go in nicely....rb25/26 would be better if it can fit and if u can put all the right parts in it - hell, you probalby dont even need a det or dett...just put a de - with 140 odd kws and 600kg it will fly! :P
edit: any interior pics?
Edited by emsta2003
Yes i have one interior pic but its with the seats removed and doesnt look that good but i will put it up.I was thinking of going rotary for this car but theres so much work involved so maybe down the line.Yes it does need a lot of restoration but then again i only paid $2500 for it :happy:
if its got a beetle motor a wrx engine or an EJ25 will be piss easy to install!
these are cool. use to be one in my area when i was young
I cant drive turbocharged car mate :P P plate restrictions.
Read an old magazine article on these years ago. Apparently the hydraulics failed in one of them and someone was stuck inside the car until they could do something about it. I can't remember the exact circumstances and what happened, but it sort of turned me off them.
Get an EJ20 or EJ25 non turbo then, they're a relatively simple engine to turbo later on if you wish, but even in non turbo form if you trick it up with an exhaust and intake it should have more than ample power to make that thing a ball tearer.
Edited by d0p3y
there are a few of them in town.
as for motor, you would need to see if the car has a engine size rating (the biggest motor you can put in that car). this would depend on state, etc.
yeh i think its 1.8L turbo or 2.5L N/A.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
