Hello how is everyone?
I Bought this car around 6 months ago and i love it.
its a Purvis Eureka kit car made of fibreglass and is mounted on a VW chassis.i bet no one on the road would think this is a 4 cylinder 45kw car :P.
Engine:VW 1600cc
Weight:600kg
Wheels:14" bathurst globe
Height(from ground to roof):1m
Tell me what you all think and What licence plates would be good for this car :happy:
https://www.sau.com.au/forums/topic/160922-who-like-my-new-car/
they are nice kit cars - looks like it needs a bit of work - but once its looking mint, expect lots of heads turning.
MR2 engine will def go in nicely....rb25/26 would be better if it can fit and if u can put all the right parts in it - hell, you probalby dont even need a det or dett...just put a de - with 140 odd kws and 600kg it will fly! :P
edit: any interior pics?
Edited by emsta2003
Yes i have one interior pic but its with the seats removed and doesnt look that good but i will put it up.I was thinking of going rotary for this car but theres so much work involved so maybe down the line.Yes it does need a lot of restoration but then again i only paid $2500 for it :happy:
if its got a beetle motor a wrx engine or an EJ25 will be piss easy to install!
these are cool. use to be one in my area when i was young
I cant drive turbocharged car mate :P P plate restrictions.
Read an old magazine article on these years ago. Apparently the hydraulics failed in one of them and someone was stuck inside the car until they could do something about it. I can't remember the exact circumstances and what happened, but it sort of turned me off them.
Get an EJ20 or EJ25 non turbo then, they're a relatively simple engine to turbo later on if you wish, but even in non turbo form if you trick it up with an exhaust and intake it should have more than ample power to make that thing a ball tearer.
Edited by d0p3y
there are a few of them in town.
as for motor, you would need to see if the car has a engine size rating (the biggest motor you can put in that car). this would depend on state, etc.
yeh i think its 1.8L turbo or 2.5L N/A.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
