Hi all just got a wierd problem I've got a power FC on my R34 now all of a sudden when i start my car it idles fine then when i turn the lights on it revs to 1500rpm then drops to 1000rpm then goes back to 1500rpm and repeats over and over then when i turn the lights off it goes back to normal. :P Anyone have any ideas my BOV is set to full plumb back im going to try putting the standard one on tomorrow and see how it goes I also think it might be the AAC valve. Anyone have any ideas???
Edited by J34
https://www.sau.com.au/forums/topic/160932-strange-idle-when-lights-are-on/
Not sure if Pfc's have "voltage compensation", but if they do, this needs to be tuned.
Either way this sounds like a tunning issue; take the car back to your tunner and ask him to ajust the tune accordingly. It could be a 2min job.
Hi all just got a wierd problem I've got a power FC on my R34 now all of a sudden when i start my car it idles fine then when i turn the lights on it revs to 1500rpm then drops to 1000rpm then goes back to 1500rpm and repeats over and over then when i turn the lights off it goes back to normal. :pirate: Anyone have any ideas my BOV is set to full plumb back im going to try putting the standard one on tomorrow and see how it goes I also think it might be the AAC valve. Anyone have any ideas???
Re-run the 30 minute idle learning procedure - this should fix it.
As far as i know to get to the idle reset requires the tune to be wipe the whole tune which i really dont want to do. I just put my stock BOV back on and cleaned the AAC valve it now idles better than ever untill I turn the lights on then its the same problem Anyone know of any Power FC Tuners close to Northern Sydney/ Northern beaches???
Hmm, I don't know anything about the PFC or how it's wired in etc. But if it were me I'd be starting with the basics, make sure the battery terminals are clean and tight, check alternator charge rate with the head lights on and off and check all earth connections. That's how I'd approach this.
It might be your AFM.......give it a dust out...while you are at it clean your filter/
This sometimes can cause your problem.
It seems to me like a air/fuel problem...you said it just started to happen....so your tune might be fine.
My nephews car use to cut out on him...until he re-soldered and cleaned his AFM's.
Could also be your injectors...put some injector cleaner in your tank.
Good luck finding your fault.
Well I drove the car to Unique auto sports today and was fixed in about a minute. Some adjustment in the idle control on the PowerFC seemed to have fixed it up :sorcerer: So free plug for UAS! :stupid:
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
