Sluggish R32
040jqm
 Share
After a night of drifting, my R32 has become real sluggish until like 4800rpm then hits like a power-band...
RB20DET
RB25 Turbo
FMIC
Walbro Fuel Pump
12psi
I am at a loss to work out the problem - can find no trace of a vacuum leak anywhere :S
Check you haven't melted your cat. I'm pretty sure mine is now clogged after a bit of a high speed workout and I've got the same problem.
I'm going to hollow it out today and see if it fixes the problem
EDIT: Just gutted my cat and the car is boosting like normal again. Only now it missfires >_<
My plugs are old so there getting changed soon and that should fix it completely
cat doesnt exist - straight thru pipes...
grrr so baffled.... its like theres a leak - cos i can hear it spooling way louder than usual - buttriple checked it all and nothing
Edited by 040jqm
Hmm, sounds like you've blown an intercooler pipe off or something... or... I once encountered a similar problem with my old 200sx and found the nuts that secure the turbo to the manifold had worked loose (turbo was loose). Pulled it off, fitted a new gasket and some decent exhaust nuts and she was as good as gold :sorcerer:
 Share
