Hey all,
Ive got a r33 gts-t with fairly simple mods including: 3" exhaust system, FMIC, dual stage boost controller and aftermarket boost gauge. A couple of weeks ago i found that while i was flooring my car the stock turbo was boosting normally hovering around the 10psi mark but then once i started to accelerate again the turbo wasnt spooling up. I tried flooring it again but the boost gauge wasnt going past 2psi???? After about 5min of normal driving the turbo started to spool up again as per usual but then after flooring it, same story.
Any ideas? im thinking maybe the wastegate is sticking open but is there anything i can do to check the problem? I had a look around the engine bay and it all looks ok no leaks or anything.
An even stranger thing happen last week, my mate is a detailer at ford so i took the car in there to give it a nice professional wash. I sprayed the engine bay with a cleaner they had and hosed it off with a high pressure hose. On the way home i gunned it to get through a yellow light and noticed my turbo was still spooling so i gave it a few test runs and it worked everytime but now the problem is coming back...
thanks for any help.
https://www.sau.com.au/forums/topic/160954-weird-turbo-problem/
I "had" the same prob with my R33, it was my BOV. Took it off about 20 mins ago
pulled it apart and gave it a good clean, the cylinder inside was scored and had a few deep scratches.
I got my dremel with a little sanding disc and smoothed out the inside of the cylinder and
the outside of the piston... just took it for a spin, prop fixed..
Hope this helps.. Kev
Money on the dual stage boost controller, I'm assuming turbosmart. Set it on high and i bet it works properly. If it does I'll explain the fix.
I second that! i got a dual stage turboxs and on low bosot exact same problem , on my second stage high boost wich is 10psi its fine. I dont exactly know why it doest it but i believe its the dual stage boost controller, very simmilar to turbo smart i think
All hoses are ok. Yeah i have the turbo smart dual stage boost controller. Ill give it a go on high setting 2moz cos its raining like mad right now. The only problem is that my high setting is on like 12psi but i cant use it cos i have stock ecu and fuel cut kicks in. I guess ill set it to the same amount as low and try it.
I let you know how i went and if your right BHDave you can let me know the fix.
Cheers
Hey guys
Well it looks like you were dead on the money. I tried it on high boost and it worked everytime. So how do i go about fixing it?
Cheers
Change your boost controller to one that is a single stage....
turbosmart does it again!
Ok, the problem is in the tee of the boost controller. It has a small ball bearing and spring in there which acts as a one way valve when you have it set on the low boost setting. So what happens is it works once and brings boost on, and then it prevents the pressure escaping from the actuator and holds the wastegate flap open, so no boost. It does leak slowly back to normal which is why it works again after 5 minutes or so.
So, the fix. Remove the spring and ball from the tee. One of the nipples on the tee is threaded and can be unscrewed and the ball and spring removed.
And problem solved!
And problem solved!
Just one thing though. If i take out the ball and spring wont that mean that ill be running on high boost all the time regardless whether the switch is on or not?
No. It's in the tee, not in the bleed section. You may need to adjust the controller to get boost back where you want it but the dual stage still works fine.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
