Autoelectrican?
You can bend the current terminals to fit a larger battery. I just used a large flat-headed screwdriver, and then fitted a longer bolt to keep it secure. Haven't had any problems since.
Is it possible to connect the new terminals to the old ones??? without changing the old terminals?
as said above, its possible. Grab a screw driver and split the ends to enlarge the terminal holes. grab a hammer and tap the ends to securly tighten it. (grab a bigger bolt also)
alternativly you could go down to your local autobarn and buy bigger terminals and do it yourself. or pay someone to do it if your lazy.
Edited by HKS99
Yep. Sorta similar to what I said above, but basically:
- new terminals go on battery posts
- long bolt through terminals
- old terminals connect to other side of bolt
- secure with a nut
Might still want to bend the old terminals to ensure that it won't come off easily.
What about some terminal adaptors? They clamp on to the new battery terminals and have a small peg that the battery cables fit onto. No fuss no muss. You can get these from Battery World in Perth for a few dollarinos.
Edited by MacGuyver
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
