2 x R32 GTS-t rims with 95% Dunlop Bathurst rubber - SOLD
Fibreglass copy GTR front bar for GTS-t - unpainted in black gelcoat, unused - SOLD
Top-ten GSM alarm - fitted to car, found to be a little overkill for our needs. -$100
- used for 6months, removed with loom and fittings in place (except dash LED status indicator)
- one remote is tempremental (solder required to the battery electrode to fix)
- for example (not THE unit for sale) of unit see: http://cgi.ebay.com.au/2Way-Remote-Control...1QQcmdZViewItem
R33 GTR OEM under-engine black plastic air diffuser -$50ono
Dominator brand (sold @ JB Hifi) central locking kit unused - $40ono
- 4 pnuematic motors
- 2 remotes
- all wiring
R32 Rear Strut Brace - $30
- aftermarket item as sold by JJR etc
Pivot Auto Shift Lamp X - $100 ono
Turbosmart Single Stage Boost Controller - $100 ono
All parts located in Adelaide, no pics yet will send on request.
Edited by Pawley
https://www.sau.com.au/forums/topic/161014-parts-clear-out/
TAKING OFFERS ON REMAINING ITEMS: SHIFT LAMP, BOOST CONTROLLER, AIR DIFFUSER & CENTRAL LOCKING KIT
RRP on Pivot Auto Shift Lamp X = $250 (inc GST)
Blinking Red Shift Lamp
Large Cut Out Aluminium Shift Lamp
Easy to Install
Lamp Brightness Control
Super Compact Control Unit
RRP on Boost controller = $249 - $279 (inc GST)
This compact design will fit in the palm of your hand. This unit provides fast boost response with one adjustable boost level. Ideal for turbo cars without factory boost controllers.
  • Switch between standard and high boost from in-cabin missile switch
  • High Boost setting is fully adjustable.
  • Detent system for ease of adjustment.
  • Gated system to bring boost on faster.
  • Includes rocker switch, mounting bracket, hose and all fitting hardware.
Edited by Pawley
https://www.sau.com.au/forums/topic/161014-parts-clear-out/#findComment-3012094
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
    • Yeah, that and throwing away opened, part used, closed back up bottles has got to be bullshit. Brake fluid sits in not-very-well sealed master cylinder reservoirs for literal years and keeps working (albeit we know we should flush it every couple of years - it actually still works). Anything kept in a bottle in the shed with a tightly capped lid has got to be a million times better than what has been in the car for the same length of time.
    • Wait, they're claiming UNOPENED fluid has a shelf life of only 18 months?
