I bought an R33 steering wheel from ebay a while ago.
When I received it I was a bit sus as it was a molded plastic rather than leather but other than that it looked exactly the same.
I only fitted it on the weekend. It bolted up ok but when I went to plug in the wires I hit some problems.
Coming out of the top of my 1996 SII R33 gtst steering colum are 2 plugs. One goes into the airbag and the other plugs into the wheel (forget where) but it is a 4 pin plug (with only 3 wires).
The unknown steering wheel has one 5 pin plug as input but then it has a plug for the airbag as well.
So my problem is that the 4 pin plug out of the steering column will not plug into the 5 pin plug on the wheel. I have 2 airbag pugs one from the column and one from the wheel.
I am sure it could be made to work if I had both wiring diagrams.
Does anyone know what this unknown wheel might be from?
Help appreciated
Cheers Darren
Edited by dwholliday
Im sure ive seen nissan patrols (05 model) with a very similar if not exactly the same steering wheel as my SII R33, different colour stitching though. Blame the nissan parts bin maybe :mellow:
cheer
Evil
Does any one have a wiring diagram for a SII r33?
The 4 pin plug coming out of the steering column only has three wires. All I need to do is to find out what these are and plum them into the new wheel.
The airbag plug is coming out of the steering column, so I can use that and ignore the airbag plug from the steering wheel. It wont even be connected.
So the 3 wires that plug into the wheel are??
1) Horn wire ??
2) Earth ??
3) ??
Anyone please
