One Word Association Thread!
Rear .
haha theres nothing to do out here! Even less to do after today...I just found out my neighbour f**ked my ute because he didnt like me tearing up the 1 designated area i tear up (its about 5m on an 87 acre block of land...). I dont know how i didnt clue in on it earlier though i mean it randomly started blowing smoke, overheated, leaks oil and the biggest give away, the bonnet latch was bent around the holder so i had to pry it open with a shovel... took me 6 hours to clue in on the possibility of (dun dun dun!)... SABOTAGE!!
Pretty much my typical day consists of work, computer and once every 2 weeks (dam petrol) i head into canberra to meet mates, buy things and get out of the house :). I used to go bush walking or just randomly wander but its too cold now so i sit here in hope that someone else is bored enough to spam this thread with me
 Share
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
