I hear the engineers at Bugatti are considering a power up using an RB30 bottom end.
Yeah, I've also heard that, can't wait to see the results.
The real madness will start when they install a GT-R fuel pump and pull 408km/h. I bet the steering wheel will start to get death wobbles then. You just watch.
And then they'd have to put ATESSA ET-S Pro and HICAS onto it to fix the death wobbles, which will then come back when they stick a GT-R badge on the back and they achieve 409.1km/h (otherwise known as warp 10), travel back to 1955 and simultaneously save the creator of the original Prince Skyline from getting hit by an old school Toyota and having the teenage mother of the current Subaru CEO fall in love with them.
This post is 100% pure Australian beef. :D
Edited by Bluprint
This post is 100% pure Australian beef. :mellow:
Whatever drugs you are on,keep 'em coming! LMAO!!
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
    • Set of knee pads for a R34. Will fit every model I think. Comes with everything except the rubber covers for the bolt holes. Still in great condition. You will need to drill holes to mount these or use double sided tape. I can do free shipping and will be shipping from the Netherlands with tracking.
    • Nistune needs something like an entire excel spreadsheet in which you build an abstraction layer that converts everything from real units you can actually measure into all of the various tables. The number of unexpected dependencies hiding in how the Nissan ECUs do math is a pretty impressive optimization trick for 8-bit MCUs but good god is it awful to actually work with in practice.
