Take care out there guys:
http://au.news.yahoo.com/070319/2/12spq.html
A Sydney doctor escaped from his burning BMW after two carjackers posing as police robbed him, locked him in the boot and torched the car.
The 34-year-old obstetrician was on his way to a north Sydney hospital after receiving a call-out at about 3.15am (AEDT) on Monday when the incident occurred, police said.
The Forestville man was sitting in his black BMW sedan at the intersection of West and Falcon streets, in Crows Nest, when two men who claimed to be police pulled alongside and asked him to stop.
After the doctor pulled over, the two men approached the car and again said they were police.
But when the doctor asked to see some identification, the men removed the keys from the ignition and pulled him from the driver's seat.
NSW Police Detective Inspector Peter Houlahan, crime manager of the Harbourside Local Area Command, said the doctor was hit in the stomach with a hammer before having his wallet, his mobile phone and his watch taken.
The two men also demanded the doctor's credit card, key cards and personal identification numbers, Det Insp Houlahan told reporters.
He said the doctor was then forced into the boot of his car.
"All he recalls is the car being driven for a period of time, stopping on a couple of occasions, and then shortly after 4am (AEDT) this morning he felt the vehicle come to a halt," Det Insp Houlahan said.
"He heard a click in the boot area and he heard someone call out: 'Get out of the car'.
"When he pushed the boot up he found his car engulfed in flames."
The doctor told police he did not unlock the boot himself, and it appeared the man's captors unlocked it before fleeing, Det Insp Houlahan said.
He said the man, who could not see the offenders when he escaped the burning vehicle, raised the alarm at a house in the riverfront suburb of Linley Point where the car was dumped.
Police believe the two offenders made purchases and cash withdrawals using the stolen cards before they abandoned the vehicle, and officers are conducting inquiries and reviewing CCTV footage.
The man was "very distraught" and tired after the attack, and was anxious to get home and see his wife and two young daughters, Det Insp Houlahan said.
He could only provide police with a vague description of his captors, but said the men were both caucasian males aged in their 20s, and that one of them was about six feet tall (183cm) with short blond hair and medium build.
The man was "extremely lucky" to have escaped without serious injury, Det Insp Houlahan said.
"The fact that it appears they popped the boot may take the edge off the offence itself but, quite honestly, it's a very serious offence and the consequences are very severe," Det Insp Houlahan said.
"This type of crime is quite unusual for this country, particularly in this area, so it is quite worrying."
Edited by sigsputnik
thats f**ked up, i thought it was my mates dad, cause hes a doctor, drives a beamer and works in the city, then i saw a snippet of the guy and REALLY thought it was him... but turns out it wasnt thank god...
im gunna be real careful if stopped by a car that doesnt have DA POLICE in huge vinyls on the side...
man that is weird. they went to all that trouble just for his wallet, mobile and watch? oh and dude, if i was you id be even more careful if the car did indeed have " DA POLICE" on the side. just a heads up
That woul dmake you think twice about stopping for an unmarked police car. seriously. Or lock all of the doors, wind the window a few cm's and ask for their ID first.
    • You will need to extend the turbo inlet pipe somehow, which could/might be done with silicone/rubber pipe, but might need steelwork, depending on your intake. And you will need to change the pipework on the outlet in teh same way, but this is more likely to need steelwork.
    • I see... Any idea how much fab work is required? I note the Hygear megathread but its like 900 pages
    • I should try the experiment you're talking about, the throttle switch is still there carried over from the R32 and it's still all wired up but after I did the whole intake manifold refurb and had to recalibrate the TPS I managed to somehow get the idle switch reporting activation at 0.22V, then when I adjusted it to 0.45V for idle it decided the engine was permanently no longer idling which caused some very weird behavior, closed loop idle was disabled so it would basically be at the whims of the cold start valve and whatever the base timing table was at. Then just unplugging/replugging the TPS with the ECU live caused it to relearn the idle TPS position and decide 0.45V was idle. Presumably there's nothing in the TPS that allows for the throttle switch to "recalibrate" like that, not easily at least.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
