hi
i got news on the weekend that the bearing in the gearbox are on the way out. I just wanted to knwo how much this will cost to fix
i have a R33 gtst. i think i read somewhere it might be about $500 depending which bearings need to be replaced. My uncle is a mechanic and he said he will pull it out for me and fix them so ill be with out a car for about 2 weeks.
My question is. Is there any thing else i could fix while i have the gearbox out and prices. I just wanna keep it nice and stockish for the moment. I was think of just putting a heavy duty clutch in from Kudos.
https://www.sau.com.au/forums/topic/161077-r33-gearbox-question/
possibly nissan would be the most expensive bet for bearings as long as u get good quality bearings made in japan than it cant be too much different in quality going after market my bearing set i got have copped a thrashing and are doing fine
go nissan for syncros though
  • 3 weeks later...
can anyone tell me how easy it is to open the gearbox up once you have taken it out. Do your need a special tool. and are the bearings press bent (If that right)
also is ther any other gearboxes that are interchangeable with the R33 box eg, s15 navara.
sorry for all the question im taking it out on the weekend and just wanna have the correct inof
Cheers
p.s
spent about two hours searching and reading couldnt find this exact info
If you can get the box bearings done for 500 bucks your doing well. Everyone seems to expect a workshop to do everything for nothing these days!
There is an hour half out and in then a good 6-7 hours to totally strip the box inspect and clean then reasemble.
S say 9 hours at a bare minimum of 70 bucks an hour (industry standard is bout $88 now!!) and there's 630 bucks in labour alone.
You will need to press the box apart and there is a HIGH risk of breaking things if your not familiar or dont hve the right tools.
hi
Hey,
edit: updated link to correct post hopefully
I did this to my R32 GTR v.spec gearbox awhile ago for just over $1000.
The entire bearing set was about $300 (could have been as low as $200 but their supplier was hoarding :))
This is for non-genuine bearings.
I would get baulk rings and gaskets from Nissan; the synchros will be about $125 ea and
the gasket set should be about $20-25.
The labour cost me $450; that was for them to do the strip, replace, and rebuild. I removed/replaced
the box from the car.
If you don't care about labour cost and/or off the road time then only fix what's broken.
If I were you I'd probably do the same thing I did to my GT-R box - bearing/gasket set, and 2nd/3rd/4th baulk rings.
Spend a little more now and avoid pulling the box to fix more worn/broken bits later.
If you're not paying for labour you'll get away for roughly $500-600.
You will need a press to remove the shafts from the centre plate; I've not seen a GTS-T box in
person but it looks similar in FAST.
Regards,
Saliya
Edited by saliya
hey saliya thanks for the info. The link didnt work it just took me to a topic on BOV's.
i should be able to get the bearing relatively cheap. If i could keep it under $500 that would be great.
Thanks again for your help.
Fixed link; PEBKAC. Check it out now...
Regards,
Saliya
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
