Hi all, first post.
ive got an R33 gtst and it seems to miss under full load from 5 to 6 grand, I had the coil packs repleace ($1400) bucks, but it still does it. ive had a boost controller fitted and a k&n pod filter. Currently running running roughly ten pounds boost. (but i dont have a boost gauge so can't be sure). Also have a 3inch exhaust system, except for the cat which is 2.5' hi flow.
Any ideas as to what the problem could be?
https://www.sau.com.au/forums/topic/16108-nasty-misfire/
Firstly check your spark plugs. How many kms has it done... has it had the timing belt and all that done... give it a good service and see if that helps.
If you running a standard ecu then you probably still have the boost cut enabled... which I think is set at 8 or 9psi (If somebody knows exactly then please let me know).
Try these first.
If that does not work then you might try a smaller gap sized plug... that worked for me.
https://www.sau.com.au/forums/topic/16108-nasty-misfire/#findComment-330130
im currently experiencing the same problem, it went away with new plugs, but it has since come back, i have done about 1000ks on the new plugs and when i removed the front 3, the first and the second plugs looked a bit used (black ring round it ect) the 3rd looked pretty much unused... no ring or marking..
it only happens when i go flat stick with more than .7 bar (10psi)
boost cut doesnt occour till something like 13 or 14 psi
https://www.sau.com.au/forums/topic/16108-nasty-misfire/#findComment-330928
I had this problem with the stock ecu... got hold of a power fc and problem hasn't come back untill I put stock ecu back in to test something else. I don't know what it is... maybe fuel delivery from the ecu seeing as boost cut is apperently at .9bar (14psi). I did also change gap sizes to .8mm.
I would redcomend that you run stock boost untill a boost guage is installed. When I first installed my bleed valve (which I'm not using any more) I still had the boost guage sitting in the passenger seat nect to me... took it for a drive and it really flew. Installed the boost guage and was actually running 1.4Bar which is WAY too much. The factory boost guage didn't even make the 7+ line.
https://www.sau.com.au/forums/topic/16108-nasty-misfire/#findComment-331415
Dan you whinge like a bitch, how much did i charge you for that bleed valve? Yeah thats right nothing. Lesson learnt boost gauge first then bleed valve, it went good though didn't it?
Anyway i think you car is brushing the boost cut, back off the boost until you throw a proper gauge in and then there are several ways such as fuel/boost cut defenders (around $ 200) and various other modules to get around this problem. Or do a Dan and get a powerFC.
https://www.sau.com.au/forums/topic/16108-nasty-misfire/#findComment-331634
Not Whinging Rhys... just giving experience... I actually thought it was quite funny and an interesting experience... ie. Learnt that stock boost gauge is shit and bleed valve (which I appreaciated and still must get back to you) was more sensitive in my car than yours. did go REALLY hard though!
https://www.sau.com.au/forums/topic/16108-nasty-misfire/#findComment-332322
leaning out at 10psi - no
cant boost skylines on std cooler - wrong
needs a fuel reg - wrong
its got to be something to do with ignition if you are in fact runnin 10psi. this means checking coil packs (done), spark plugs, and ignition module. however if the spark plugs are uneven in colour it may point to a blocked/clogged injector which isnt spraying enough fuel causing pinging, but youd hear that...
is it missing on idle and all the time, or only in high rpms? what gap have u got your plugs set to?
https://www.sau.com.au/forums/topic/16108-nasty-misfire/#findComment-333350
On only 10psi it won't need an adj. fuel pressure reg.
The standard ic's are fine to run 10-11psi on the r33's and on the r32's around 12psi. I made 152rwkw on 12psi.
When going to a fmic i noticed ever so slightly more lag and that holding 3rd and fourth out didn't seem to feel as flat.
https://www.sau.com.au/forums/topic/16108-nasty-misfire/#findComment-333395
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
