Hi all, first post.
ive got an R33 gtst and it seems to miss under full load from 5 to 6 grand, I had the coil packs repleace ($1400) bucks, but it still does it. ive had a boost controller fitted and a k&n pod filter. Currently running running roughly ten pounds boost. (but i dont have a boost gauge so can't be sure). Also have a 3inch exhaust system, except for the cat which is 2.5' hi flow.
Any ideas as to what the problem could be?
https://www.sau.com.au/forums/topic/16108-nasty-misfire/
Firstly check your spark plugs. How many kms has it done... has it had the timing belt and all that done... give it a good service and see if that helps.
If you running a standard ecu then you probably still have the boost cut enabled... which I think is set at 8 or 9psi (If somebody knows exactly then please let me know).
Try these first.
If that does not work then you might try a smaller gap sized plug... that worked for me.
https://www.sau.com.au/forums/topic/16108-nasty-misfire/#findComment-330130
im currently experiencing the same problem, it went away with new plugs, but it has since come back, i have done about 1000ks on the new plugs and when i removed the front 3, the first and the second plugs looked a bit used (black ring round it ect) the 3rd looked pretty much unused... no ring or marking..
it only happens when i go flat stick with more than .7 bar (10psi)
boost cut doesnt occour till something like 13 or 14 psi
https://www.sau.com.au/forums/topic/16108-nasty-misfire/#findComment-330928
I had this problem with the stock ecu... got hold of a power fc and problem hasn't come back untill I put stock ecu back in to test something else. I don't know what it is... maybe fuel delivery from the ecu seeing as boost cut is apperently at .9bar (14psi). I did also change gap sizes to .8mm.
I would redcomend that you run stock boost untill a boost guage is installed. When I first installed my bleed valve (which I'm not using any more) I still had the boost guage sitting in the passenger seat nect to me... took it for a drive and it really flew. Installed the boost guage and was actually running 1.4Bar which is WAY too much. The factory boost guage didn't even make the 7+ line.
https://www.sau.com.au/forums/topic/16108-nasty-misfire/#findComment-331415
Dan you whinge like a bitch, how much did i charge you for that bleed valve? Yeah thats right nothing. Lesson learnt boost gauge first then bleed valve, it went good though didn't it?
Anyway i think you car is brushing the boost cut, back off the boost until you throw a proper gauge in and then there are several ways such as fuel/boost cut defenders (around $ 200) and various other modules to get around this problem. Or do a Dan and get a powerFC.
https://www.sau.com.au/forums/topic/16108-nasty-misfire/#findComment-331634
Not Whinging Rhys... just giving experience... I actually thought it was quite funny and an interesting experience... ie. Learnt that stock boost gauge is shit and bleed valve (which I appreaciated and still must get back to you) was more sensitive in my car than yours. did go REALLY hard though!
https://www.sau.com.au/forums/topic/16108-nasty-misfire/#findComment-332322
leaning out at 10psi - no
cant boost skylines on std cooler - wrong
needs a fuel reg - wrong
its got to be something to do with ignition if you are in fact runnin 10psi. this means checking coil packs (done), spark plugs, and ignition module. however if the spark plugs are uneven in colour it may point to a blocked/clogged injector which isnt spraying enough fuel causing pinging, but youd hear that...
is it missing on idle and all the time, or only in high rpms? what gap have u got your plugs set to?
https://www.sau.com.au/forums/topic/16108-nasty-misfire/#findComment-333350
On only 10psi it won't need an adj. fuel pressure reg.
The standard ic's are fine to run 10-11psi on the r33's and on the r32's around 12psi. I made 152rwkw on 12psi.
When going to a fmic i noticed ever so slightly more lag and that holding 3rd and fourth out didn't seem to feel as flat.
https://www.sau.com.au/forums/topic/16108-nasty-misfire/#findComment-333395
    • Thanks for your insight, it being basically useless will impact my decision for sure. I thought it may help the engine breath better I guess. But then again, I have also been told that tuning an RB20DE is also not worth it. Exactly, we follow EU Regulations. There is a bit more leeway on older vehicles. My Porsche 924 came without a cat from factory and managed to pass, they still mentioned that I have quite high emissions on it though.
    • My apologies, I stand corrected. Thanks for registering to mention this! And thank you for actually reaching out to the council to clarify. This is the sensible thing to do and the opposite of what I was alluding you were doing. I may have seen too much outrage and hate being fueled on the internet and it has made me a somewhat cynical old man. Sometimes it is easy to forget that there are real people behind websites and accounts. In my defence, CarExpert and CarExplore do read quite similarly at a glance. I shall try and do better in the future. (Please stick around to get the latest scoops on dealing with old Nissan shitboxes )
    • Don't bother. The poor little RB20 doesn't make enough gas flow to challenge the flow capabilities of even the littlest cat, and you won't make any extra power, and all you'll do it soot up your rear bumper. Plus....is Malta not runing under Euro regs?
    • Hey Daniel, sorry to hear that and thanks for posting up for us at a really hard time I only knew SmoothLine through the forums, we never met as we are based in different states, but when he was most active on here he was quite a while back so not many of the current crowd might remember him. I am pretty sure he was active in the Queensland SQU club but that is defunct now too (times are changing and we are all getting older). Farewell SmoothLine!
    • Turns out depending on whether the car was equipped with TCS or not there are different signals coming to the dash, meaning there are different speedo clusters.  Wired in a speedo calibrator box from aliexpress and now works fine.
