  • 3 weeks later...
1) chuck on a front mount
2) take off that ugly scoop on the roof
3) delete the front foor handle aswell
4) delete the rear spoiler
But mate I got to say that is a neat job you have done so far.
Chop a series 2 r33 gts-t next, take of d spoiler, drop it on its guts. some nice rims, no spoiler, would look mint.
