sit the clutches next to each other on the floor and measure the diaphram height from the ground, if its the same chances are the carriers will be the same if the new clutch is shorter you need a longer carrier and if it is taller you need a shorter one.
im using a nismo tripple. i used one a little shorter. th eos 12mm one is to short.
is it this one? this is the usual twin plate carrier. if you aint got one it is the factory GTi-R part.
  • 1 year later...
