just letting you guys know about In Tune Performance. just had the timing belt done (fitted gates performance belt), walbro 550hp fuel pump fitted, all front belts , coolant and fuel filter replaced and safc2 dyno tuned. cost 350 to fit everything (had all the parts) and 160 to dyno the safc. went in with 256rwhp and come out with 271rwhp (could be cause of different dynos). car definately sounds happier(exept for a bit of noise from the new timing belt (was expected)). recommend him for work south of river. located at unit 3/28 salpietro st, bibra lake. ph 94346608,Aaron Gregory. :laugh: p.s. he has no eftpos so cash only :mellow:
  • Replies 41
  Pal said:
just letting you guys know about In Tune Performance. just had the timing belt done (fitted gates performance belt), walbro 550hp fuel pump fitted, all front belts , coolant, oil and fuel filter replace and safc2 dyno tuned. cost 350 to fit everything (had all the parts) and 160 to dyno the safc. went in with 256rwhp and come out with 271rwhp (could be cause of different dynos). car definately sounds happier(exept for a bit of noise from the new timing belt (was expected)). recommend him for work south of river. located at unit 3/28 salpietro st, bibra lake. ph 94346608,Aaron Gregory. :D p.s. he has no eftpos so cash only :blush:
hey pal, so what parts did you take yourself exactly ? i want to do the same thing.
he did not fit the safc , only tune .did not change oil. only coolant and fuel filter. i took in a new gates timing belt, fuel pump, alt belt, power steering belt and aircon belt, all from repco, cost about 170 bux for all the belts and ebay fuel pump. hes not keen on pfc's (haltec man) but give him a ring.
  • 2 months later...
ive just had my 32 come back from intune and very happy. aaron looked after me with any problems i had. i got a haltech e-11 installed and tuned x force exhaust, 550 walbro pump, plugs, fuel filter and the map sensors for the ecu done too. i need injectors too but ran out of time with them as i am moving to karratha, so to stop it leaning out the rev limiter has now been set to 5800 rpm untill im back in perth or have the car sent down. but yeah give him a call he is very good
Ive only heard good things about them inc some extreme Race cars and i think they were one of the Shops that did the Training with Wolf over the last 2 weeks.Must be good with Microtech
As their tuning an S6 RX7 Drag car with 20B Quad rotor PP with 3 GT40 ITS Turbos and lots of NOS,Very tough car to tune.
hey Daniel, wot sort of power did u get out of that setup. looking at the same setup for my 33
At the moment the car is only making 225 rwhp because the injectors are maxed out and i had run out of time to get bigger ones (i moved to karratha)
also because the injectors are maxed out the rev limiter is now set at 5800rpm instead of 8000rpm to stop me blowing up the motor.
And the car is actually n N/A and aaron reckons it should be making around 270 to 280 rwhp with bigger injectors
E manage is well under $1000 - and probably your cheapest option. I gives full ecu functionality with alot of extra features, but still utilises factory coldstart, accel enrichement, idle control etc - emanage ultimate comes with laptop software for tuning too.
They are an interceptor type ecu, so nothing too major to wire up.
Considering power fc is getting a bit scarce (new, around 1K - but they stopped manufacturing), emanage would probably be one of the cheapest, best options.
your best bet would be to do a search in the performance section, or post up there if you cant find what you are looking for - at least that way you wont be accused of whoring other peoples threads :thumbsup:
your best bet would be to do a search in the performance section, or post up there if you cant find what you are looking for - at least that way you wont be accused of whoring other peoples threads :D
  Pal said:
the safc2 is only a piggy back to the ECU. to replace the stock ECU you will need to go to a power fc, haltec, e-manage, EMS. these will cost from 1500 up to buy, and 500 up to fit and tune.
yeh, what steve said
    • Given you already have the engine cross member to match and likely gearbox mount to. The SR20 has a head start on the RB in this case. They handle GREAT with an SR20, lots of fun.   One I did back in the day
    • have no doubt and wanted too trust me and may regret later not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 馃榿 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha 15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
    • Purely out of curiosity, how do you know all this @dbm7? Do you work with automatic gearboxes professionally? This goes way way way beyond "I've had an automatic Skyline once and did some mucking around"
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
