Which Ecu?
SKY 34
 Share
hi guys...
I pre-ordered a V500 plug in for GTT to realise that it cannot be ready in time for mods.... so I'm left with a few options here. all of which uses piggy back comp...the TCS is already disconnected, so won't have problems with lights lighting up..
anyways what are the advantages and disadvantages for piggyback comp..
the ECU will be required to
-run up to 500rwhp map
-run aftermarket fuel system
-control the NVCS
-run MAP
here's the option..
-v500 the non plug in version. Piggy back
-new Greddy ultimate Piggy back
-Haltech Piggy Back
-Motec M48 stand alone
-HKS F-con
thanks
-Haltech Piggy Back
There my choices if you would like to save some cash with a good unit I would say the greddy ultimate, cheapish but I like it. I got one going in to my gtt soon.
I spoken to garage owner..he ruled out e-manage both the ultimate and the normal one...he said it only alters signal in comp..not a real computer..sumthing like that...anyone care to explain e-manage limitations?
cheers
No piggy backs...lol
They are limited in some tunning options.
Motec is the way to go.
Find a tuner who has used it and go from there.
Motec is out of his budget i would assume.
Its nice to have the best of the best, but reality sometimes says thats not quite right
Why cant you wait for the new ECU to be delivered?
The Motec M48 is still within my budget I've set aside approx $2-3k..
the problem atm is the vehicle is a daily car...It was initially planned for the car to enter workshop during easter break..but then there's event I need to go to during that time..so everything is pushed forward...
although the wolf v500 I think it's a complete ECU in a way...it just doesn't control the misc stuff such as climate control..etc etc...
another options btw..haltech ECUS... anyone used them before?
  • 3 weeks later...
got a haltech e11v2. easily run 500rwhp if you want to spend 2-3k. they are great ecu as well. for an extra 100$ ya get an closed loop boost solonoid/controller. and i believe you can get a plug and play loom for you car.
i am currently looking at the same haltech. and if i can afford after the bills are gone then im going it!
i hear the haltech can contriol almost anything in the car thats controlled by the ecu.
the haltech interceptor(piggy back) is also a great choice but probably be best going for a full ecu.
i have a friend that had an e6x installed in his car and said thats the best thing he has ever spent his money on. before that he had a EMS
Edited by Turbz_13
man i was gonna run a v400 stand alone ecu or a microtech... arent they good enuff? is it necessary to spend an extra grand or 2 for...
climate control?
i mean u can always stick some wires and one of those battery fans on ur dash n deres ur climate control ;)
nehow man try to buy more time.... the piggy backs are just shit n waste.. :)
 Share
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
    • Oh for sure, I'm just recounting my thoughts 😎 I'm not what you've got there to fuzt with.... likely my first idea was on the money -- rebuild or replace connectors. You can get a lot of connector stuff here  -> https://www.rapidcables.com.au/ Didn't look in the boot of mine, because I replaced these when I renewed the pump (plastic of connectors had gone brittle) edit: what I used... https://www.efihardware.com/products/2120/Deutsch-DTM-Connector-Kit-6-Pin ...cheaper... https://www.ebay.com.au/itm/364900039138
    • In no way was i suggesting it’s your fault mate. The trailer cable has a plug that I removed. I will have a closer look, but I did remove the trailer wiring cable with the tow ball as I don’t need it on my silo. i have replaced the fuel pump already there’s no need to remove the cradle again I can see the wire colours from it in.
