ive taken them all off and im ready to primer and paint.
the paint i want to use is the deep red/maroon colour, does anyone know where to get it from?
also what primer am i supposed to use for high-temp parts?
heres a pic of the colour i want to use:
i just did our 26 all products from local autobarn;
K&H etch primer
VHT engine enamel colour of choice
VHT engine enamel clear
VHT is the shizzle as it actually cures with heat and is vurtually indestructable if done properly.
K&H etch primer
thanks for that mate. do you have pics of how it came out?
look for a product called metal cast by dupicolor.........they have that red and is heat proof and give a metalic finish.
2 step system spray the silver and then the red, look sweet.
did my brakes and engine parts in it.
Hasn't chipped or worn off yet!
thanks for that mate, where do you get it from? do you have pics?
i will take some, it came up as good as any 2pac jobs we have done in the past.
sweet as. thats the stuff ill be using then :)
K&H etch primer
did you oven bake your painted items?
i had VHT on the valley cover of my rb25 - was painted and car was run and used for about 4 weeks, then when it came in contact with overpsrayed Carbie cleaner it came off on those spots ..
seems like running temps aren't good enough to cure them, well to me anyway
sweet as. thats the stuff ill be using then :(
if you can wait a few days, the camera is on its way back from WA :) its yellow too :(
does any one know if anyone did a DIY or a writeup of pulling this apart and spraying it?
I have read threads in the past and think i will have a go soon but wondering if anyone has any links ... thanking you
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
