When: Saturday, 14th of April 2007
Time: 10:30am – 4pm (Cars on-show need to arrive from 9:30)
Where: Location: Horseshoe bend farm (Horseshoebend Road in Keilor)
Cost: Donation to show your car of $10 Per car, And a $5 Entry donation to view the show.
WestNew are holding a Show and shine to raise money for their organization and have asked us Skylines Australia to come and support them in their efforts to raise money to help adults with disabilities.
WestNet provide a client focused, diverse range of high quality programs which maximize clients’ rights, dignity, opportunities and independence.
Please come down and help support this event by cleaning up your cars and coming down to show them off..
A BBQ will also be run on the day to again help raise money.
This event will be covered by the local Press so a great opportunity to get you there show off your cars and also have them pictured in the local newspaper.
Come on guys this is for a really good cause. We know there are a lot of events on it a year, but this is one we should try and give our support to and help those who support others in need.
I'm sure they wont mind if you bring a friend or a non Skyline along, as long as it's an interesting car.
I would like to announce that SAU Vic is going to sponsor this event by covering the cost of every SAU Vic Members car who enters into this event, and displays their car.
I have also been informed that there will be a media presence at this display covering the event for a local newspaper.. This is not only a cool oppertunity to get your car pictured in a news paper but also a fantastic opportunity for SAU to display to the public that a car club cares for the community and that we are trying to do our bit for society.
OK udated confirmed cars are:
- Evil (Me)
- fuzzy_scuz
- Skyhy
Possible:
- basti
- espo
come on guys! any type of car is welcome... 5 cars would be awesome!
basti, espo: any news about if you can commit to this great event?
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
    • RB20/25 covers don’t have threaded fasteners stock like RB26 covers. They are blind rivets so I will need to drill out and tap threads. I bought some M4x6mm button heads and will report back once done if I chose correctly length wise.    have also got some loctite
