Hey there,
Recently the RB20det in my cefiro blew up,due to error on my behalf (well not really blew up but some vavles made slight contact with 1 and 5 pistons)
So i have undertaken a full rebuild on the engine which included, pulling the block apart, sourcing new R32 head which has been acid dipped, shaved slightly, new guides, new valve stem seals, "machined" vavles and pressure tested. The original block has been decked, hot tanked, (acid dipped) honed and pressure tested (as well as pistons and rods). Everything that came out of the engine e.g. crank and pistons and rods turned out to be fine.
I have sourced standard rod and mains bearings through nissan as well as new rings, oil pump, water pump, timing belt and complete gaskit set.
This weekend i am looking to re-assemble the egine starting with the bottom end with alot of help from some friends who know alot more than me about this kind of work.
My questions are, does anyone out there have the correct torque levels for rod bolts, crank, oil pump ect ect?
Also when it come time for running the engine in are there any tips or rules as to what needs to be done, i have done a bit of research in that area but usually had mixed messages about the running in period.
Also is there anything i should be doing whilst the engine is totally apart, for example adding oil restrictors to the block for head oil feed?
I was thinking of taking photos of the entire build, does anyone else think that would be a good idea, or be interested?
Thanks
https://www.sau.com.au/forums/topic/161172-rebuildingrunning-in-a-rb20det/
I was told to keep it off boost. Some say to give it boost but not too much.
Either way I went with what my engine builder recommended and have had no problems. No oil usage, good extremely equal compression good power and fuel economy.
Basically.. I wired open the wastegate and drove it as n/a. I gave mine lots of throttle and varied engine speed avoiding cruise and in gear deceleration at all costs. The majority of my running in was done along the seafront down south through round abouts. Basically every time I accelerated I gave it full throttle, I varied the rpm of which I changed gears at.
Initially I started the car let it idle for a few mins while I checked for leaks. I then hit the street for 10mins driving it with moderate throttle, got home and dropped the oil/filter. New oil in and then straight down the dyno for a quick afr check, then from there onwards I rev'd it to 4000-4500rpm, not all the time but the odd in gear hold through second gear.
Its how my engine builder recommended the run in. Lots of throttle, varied rpm, no gear deceleration (pop it in neutral), no extended cruising or idling.
Good luck. :blush:
Also.. Blackwood auto & dyno used to do cheap as power/afr checks for $30. This was a couple of yeares back now though.
Thanks for information, was tempted just to take it to a engine builder and have them assemble the engine for me but i would like to see how everything is done. Graham from Boss racing Differentials is helping me put it together as he used to build all of his old drag V8 engines a while back (i know a old school V8 is totally different to a RB20 lol)
Hmm i was thinking of taking the car into the hills but i would be tempted to de-accelerate in gears which i know is not really good for the run in period. Might do what you did Cubes and just take it down the espy from Moana to Aldinga a couple of times, aparently the first 50km of run in are the most important.
Also did you use a synthetic oil for run in? I always used use Motul 300V 10-40w before, but i have heard its a good idea to use mineral oil for the first 1000km's or so of run in then start using the synthetic stuff later on
As cubes mentions AFR's are very important.
I think boost is fine as long as its low boost. I ran mine in with about 5 - 6 psi. Low rpm is key as well. My limiter was
set to 5000 rpm for the run in.
It's also important to put varying load on the engine during the run in. Taking it down the freeway and sitting on 100km/h only is not a good thing.
Its worth going through a hills area that will load up the engine a bit.
Changing the oil during run is very important to. I was pretty keen with this.
Engine was first filled with run in oil but most people say any mineral oil is fine.
First fire up ran it till it got hot at about 2000 rpm.
Shut down change the oil. This gets most the assembly lube outa the engine.
then did 100km/s oil change
then another 400ks then change oil and went to synthetic
then 500k's and another synthetic change
total 1000k's and then time to tune it for full rev range.
Take heaps of pics of build too. People always interested :blush:
Cool, thanks for the help.
one more question i have is should i go for a oil pump collar for my new oil pump or just let it drive off the usual spot on the crank? Its not really a highly tuned engine, only had around the 200rwkw mark before witha Rx7 hybrid turbo on in, was running quite rich too, i will be turning my boost controller off for the run in which means it will be running 5psi of fury haha.
Ill be sure to take photos of the build
http://i3.photobucket.com/albums/y65/Ceffy_SA/DSC00759.jpg
http://i3.photobucket.com/albums/y65/Ceffy_SA/DSC00777.jpg
http://i3.photobucket.com/albums/y65/Ceffy_SA/DSC00781.jpg
Flintstones power^^
Load up where u can, let it warm up to about 45 degrees before moving, keep it under 4500rpm and as your k's increase you increase th rpm/boost as well you dont want rich afr's theyll just wash the bore down, and Comments above aswell And Varying rpm, no really long straight runs at constant rpm, If your at the lights for a couple of minutes vary the rpm give it a stab to 2000rpm every so often.
Oh and oil changes
100, 500, 1000, 2000, 5000, and then your regular intervils
Plenty of ways to do it
Worth getting new rod bolts and head bolts? Have been thinking about it, might as well do it properly the first time around
Edit: Just rang Nissan, Rod bolts are only $6.85 each, rod nuts are $1.50 each and head bolts are $4.30 each so all up it comes to $160.4 for new rod bolts/nuts and head bolts so i think ill be getting new ones. Just out of interest how can they charge over $2400 for a new set of hydraulic lifters (24), sheesh!
Edited by Ceffy_SA
get some ARP rod bolts and so on... spend the extra for quality.
as for run in.. im a firm believer of running it in like you would normally drive it. Read this article for more info. RUNNING IN
Ive had rotors, and several other piston motors built up. and have always run them in hard, While not absolutly thrashing them by sitting on the limiter etc. But rev them out and load them up!
light load and low revs will result in a motor that is un responsive!
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
