  • Replies 88
Posted Images
Getting the IAT sensor replaced, I am warming to the r33 wheels, but would like not to spend much money on the car for a while, the amount I've spent on it in the last 2-3 months is annoying :blink: thx for the comments though
  • 1 month later...
sorry to hear about your car jason. :blink:
Well car is now doing 267kw atw @ 15psi
Thats where I'm leaving atm, happy with the power, and poor enough... Need to save up for a respray now, cars collecting scratches like nothing else, had the car at three shops this week, for various things, now have a scratch on my bonnet..... My poor car looks so rough and dodgy atm.... :)
Car still has a slight miss at 2500-3000 which I need to get nutted out. Any ideas? Compressor surge?
  • 2 months later...
  • 4 months later...
  • 4 weeks later...
  • 2 months later...
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
  • 4 weeks later...
  • 4 weeks later...
  • 2 months later...
  • 9 months later...
In other news, not driving this much anymore. Using the daily I bought 09 Kia Rio FTW lol. Paint is going to shit, and I think the engine is getting a bit tired. Long term I want a full respray done in the same colour, and an engine rebuild.Still undecided if I want to go a normal rebuild on the 25, or do a 25/30. Thats very long term though.
  • 3 years later...
Not much of an update but still have the car, starting to ponder if I should respray the car in Bayside blue again and keep it rather than sell it, as the values are down so low for 32's now. Had bouts of wanting to sell it and not sell it.
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
