yesterday was a tad emotional for myself... after 2 years ownership, i saw my r33 drive away with its new owner
its not going to far so chances i will still see it around
thanks to all who helped me out with it, lent me parts when the defect/epa issues arose! and made me feel apart of the club...
the r32 is also for sale and hopefully will be gone too... im giving skylines a break... but staying nissan...
won't be leaving the club.. however will feel a bit of a stranger without a skyline
Photo of my precious baby... well not mine anymore : (
-Ruffels
https://www.sau.com.au/forums/topic/161222-a-sad-day-for-me/
You're welcome :stupid:
Mine's not far behind, so I know how you feel
You're welcome :(
thanks heaps for the lend of the exhaust ... made life so much eaiser, good luck with the ale, took me almost 12 months to sell, but im happy with the buyer and i know hes gonna take good care of her!
thanks to al for the lend of the exhuast also, thanks for paul for the use of his standard boost controller, and everyone else who helped me out along the way
sorry to see it go mark but not much u can do hey
u should be off your p's soon though ?
mmm was a bit of a teary moment, umm nah not off p's for another 18 months unfortunatly
so i gotta get me an australian spec S15, which is unfortunate because they are so much more expensive then the jap spec ones!
oh well
-Mark
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
