Hey,
Have had this problem for a long time, but would like to fix it as the sound isnt really pleasing :)
When i have the window down (at any height) the door seems to rattle around when driving. When i go up/down a speed hump you hear the door clank up/down to the movement.
Also, when i turn a corner, or a u-turn, the door makes a loud rubber squeaking sound as the turn is made. Was really annoying on skidpan as all you could hear is the door rattling/squeaking.
Im not sure what needs to be replaced to stop my driver door causing all of these sounds.
Some people have mentioned that it is the window moving and not the door, but im pretty sure its not as ive put my arm on the window to stop any movement :)
Other symptoms which could have some effect?
- When the window is put down, it jolts the door on the first movement.
- The rubber seal around the door clamp (near the light switch which turns on light when door opened) has peeled off, perhaps this is causing the extra movement?
- Door doesnt seem to sag excessively.
Thanks all
- Patrick
https://www.sau.com.au/forums/topic/161237-r32-door-rattlesqueeks-on-turns/
  • 1 year later...
take the door trim off and drive around, will be easier to find whats causing it. Almost sounds like the rivets that hold the power window assembly are starting to wear.
Edited by Jamesrb25
damn what a bump haha.
Ive fixed the problem by now, this thread brings back to when i had that annoying problem haha.
My problem was the rubber on the U-Latch was worn. Not sure what its called, the latch which the door locks onto to hold the door shut haha.
Due to the worn rubber, they door would rattle because of it.
Easy fix is to swap the latch with the passenger side. As that one is usually less worn it will hold the door nice and firm.
However the u-latch is a tricky thing to mount properly. If you dont mount it properly your door might stick out a bit when closed.
Hope that helps
Not the best solution, as it tightens up the latch if you put too mcuh on and makes it hard to open the door! Just been experimenting with different amounts of tape-but at the end of the day it works as intended
Cheers for the fix!
  • 5 years later...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
