Hey guys wondering if anyone here has changed their factory xennon bulb and ballest successfully to a higher temperature spec (6500K etc)
Im looking to change mine but unsure of what xennon bulb it is weather H9 , 9009
I do know by changing the xennon bulbs to a higher temp varient gives better light and performace from the stock ballest
Has anyone done something like this??
Thanks
Give you a Idea These one are available on the market ..
Edited by 53XYN
https://www.sau.com.au/forums/topic/161277-r34-xennon-bulb/
So you want to make the R34 xenons brighter... why would you want to do that? They are bright enough already and I reckon any brighter and they'll be c**p - not to mention risking you lenses melting down on you :dry:
https://www.sau.com.au/forums/topic/161277-r34-xennon-bulb/#findComment-2995428
Vish, i bought those 6500K bulbs off you a while back, and i put them in my car. Ive had no problems at all. an they look great.
They were replacement halogens I assume? Vish, if you have factory xenons I wouldn't touch them. Go any brighter and it'll be like high beaming ppl everywhere you go.
https://www.sau.com.au/forums/topic/161277-r34-xennon-bulb/#findComment-2996183
ah yeah i remeber you bought that HID Xennon kit off me , wasnt your car converted ti H1 ?my xennon says H9 on it so im aussuming its a H9 bulb ..
Reason im replacing it is the factory ones are getting dimmer one side .. time to get them out and in with new ones...
John i still have those H1 halogen bulbs MTEC brand 4700K ones if uw anna grab them off me sometime this week
https://www.sau.com.au/forums/topic/161277-r34-xennon-bulb/#findComment-2996270
So you want to make the R34 xenons brighter... why would you want to do that? They are bright enough already and I reckon any brighter and they'll be c**p - not to mention risking you lenses melting down on you :(
I've just got the stock ones still in mine and people still flash me as they think i got high beam on. Good to see whilst driving but yeah any brighter and a waste and asking for trouble.
https://www.sau.com.au/forums/topic/161277-r34-xennon-bulb/#findComment-2996277
Well not really instead of yellowish xennon id prefer white , and plus makes car look newer too .. ive seen a 33 with 12,000K on it S2 they have plastic lenses as well dont know what temp these things will melt :D
https://www.sau.com.au/forums/topic/161277-r34-xennon-bulb/#findComment-2996280
Well not really instead of yellowish xennon id prefer white , and plus makes car look newer too .. ive seen a 33 with 12,000K on it S2 they have plastic lenses as well dont know what temp these things will melt :(
Umm mine are already white.. my parkers are the yellowy colour.
https://www.sau.com.au/forums/topic/161277-r34-xennon-bulb/#findComment-2996292
Are u 100% sure u've got xenons? When u turn them on, does it take a few secs to fully illuminate to full brightness? If they are yellow sounds like u've got halogens! :(
https://www.sau.com.au/forums/topic/161277-r34-xennon-bulb/#findComment-2996507
Always remember; just because your headlight casing says "Xenon" does not mean you have xenons :bunny:
yep sure do have xennons , takes a few seconds from yellow get a lill whiter it is whiteish nothing compared to the 6000K ones , im thinkin the stock ones are maybe 4700k? ...
Anyone here removed the bulb and the ballast from their car b4?
https://www.sau.com.au/forums/topic/161277-r34-xennon-bulb/#findComment-2997066
Something doesn't sound right... you have described the xenon warm up process correctly but it should not be "yellow" to start off with - mine are white from the beginning.
Maybe you need to give the lens a good polish to remove any residue that's formed up over the years = that may be the cause of this "yellowness".
Removing globes and balasts is easy - not really reccommended though as the less dust you expose the globes to the better life they will have.
https://www.sau.com.au/forums/topic/161277-r34-xennon-bulb/#findComment-2997110
Ok i have checked the lenses out polished them again with meguires plastic X came up clear n like new .. still starts off with yellow then goes white.. i think maybe my bulbs are on the way out as one side is completely dim..
So no one knows what xennon globes they use? Nissan isnt any help at all as they dont know
https://www.sau.com.au/forums/topic/161277-r34-xennon-bulb/#findComment-2997910
From memory someone said something about the Nissan globes costing close to $400 a pop when they last checked (must be over a year ago now)
There was someone (I remember clearly) who said that Hella make a substitute bulb which is like $40USD. Do a search for R34 Xenon Bulb I guess.
Still strange how it starts off yellow - first time I've ever heard of that.
https://www.sau.com.au/forums/topic/161277-r34-xennon-bulb/#findComment-2997955
yeah i know i can get a whole new kit made by hella for 400 bucks including ballest.. thing is im not sure on the type of bulb it uses... ah well this weekend i might try and pull it out as i need one side fixed b4 i get defected
https://www.sau.com.au/forums/topic/161277-r34-xennon-bulb/#findComment-2998199
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
    • 98 and 95 have to meet the same national fuel standards beside the actual RON.  91 has lower standards (which are quite poor really), so 95 is certainly not 91 with some octane booster. It would be an easier argument to claim 98 is just 95 with some octane boosters. Also RON doesn't specify 'quality' in any sense, only the octane number.  Anything different retailers decide or not decide to add to their 95 or 98 is arbitrary and not defined by the RON figure.
    • Anyone know alternatives to powerplus tungsten? Can't find an alternative online.
    • 95 is just a scam outright. 98 is the real "premium" with all the best detergents and other additive packages, and at least historically, used to be more dense also. 95 is just 91 bargain basement shit with a little extra octane rating. Of course, there's 91 and there's 91 also. I always (back in the 90s early 2000s) refused to put fuel in from supermarket related fuel chains on the basis that it was nasty half arsed shit imported from Indonesia. Nowadays, I suspect that there is little difference between the nasty half-arsed shit brought in by the "bargain" chains and the nasty half-arsed shit brought in by the big brands, given that most of it is coming from the same SEAsian refineries. Anyway - if there's still anything to that logic, then it would apply to 95 also. 98 is only made in decent refineries and, as I said, is usually the "premium" fuel, both in terms of octane rating and "use this because it's good for your engine because it's got the unicorn jizz in it!".
    • Yeah since those first 2 replies I actually went and put some 98 in it and tbf it's already doing much better than the 95 (which is weird and makes my inner tinfoil hat wearer think the 95 was a crap batch), getting 8ish around town. Again, wonder if it takes a while to stabilize if the fuel is changed a couple of times. I swear cars used to just either run "well" or "s**t* in my 20s, none of this fuel optimisation business haha
