xenons shouldnt get hot on the actual bulb so the reflector itself shouldnt be affected from heat to much. In my expereince the lens do get a bit hot though. The D2R is a fairly standard bulb, if you guys are looking for replacements, I'd have a look at the Philips range. I work with a certain company that wholesales electrical gear like this all day long, ask your local parts shop (repco or autobarn for example) about the new range of philips coming out. I've seen the pricing, you can buy a pair of bulbs for the same price as one of the old bulbs. Worth a look. If they don't know aout em, tell em to look them up.
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
